No Pan Axis ESC data. Contact DJI support
9612 26 2019-8-15
Jondle
Hi all. I’ve just got a new DJI Ronin sc.
I’m having a few issues. One about the focus wheel yesterday (which I think I’ve fixed).
However today the unit is not power on.  In the app status it currently says “No pan axis data. Contact dji support.
Does anyone know what this means?
2019-8-15
laurenceplevin
Guernsey
any solution? I'm having same problem
2020-1-1
laurenceplevin Posted at 1-1 12:05
Hi laurenceplevin, sorry to know you have the same problem. May we verify whether the Pan axis is working and can it be controlled? When does the issue happen? Was it balanced properlly before powering on?
2020-1-2
laurenceplevin
Guernsey
HI there, it was all working correctly then one time when I turned it on nothing is responding correctly. I have always balancing before using it as well. I'll attack a photo of the checklist I am getting.
2020-1-2
laurenceplevin
Guernsey
Just reset everything and used a different lens for my camera which made me rebalance it differently and its working now thanks
2020-1-2
laurenceplevin
Guernsey
However now when I have turned it on again it shakes a lot and beeps, it then automatically puts itself in motor pause, any ideas?
2020-1-2
laurenceplevin
Guernsey
Well now I solved that problem its gone basic to the original problem. Everything is balanced, was auto tuned and working fine then after about 3 mins of use it stops and gives me the thing I started with
2020-1-2
Adam.from.Maine
I'm having the same issue. "No Pan access ESC data" Unable to turn gimbal on, have tried rebalancing, different phones with updated software. If holding power button on, bluetooth is registered to phone app, still unable to engage motors or turn on 'green' lights between modes. Was working fine prior to putting away previously (5 days ago).
Has anyone resolved this issue?
2020-2-8
djiuser_zSjVExJWAip9
India
Hi i have an issue
2020-7-1
India
What do i do to get this no data issue
2020-7-1
djiuser_lAhla3dTayn2
My gimbal is saying the same thing how do I fix it
2020-8-25
2020-8-25
Jondle
Hi, I haven't been on for a while now. But just to update anyone reading this threat.
In the end, after looking thought the forum and a solution. I contacted my supplier of the Ronin and they recommended that I return it (It was in warranty) and they sent a replacement which works perfectly fine
now. I'm sure there could be a solution to this but at the time I had the option to save the headache and just replace it.
2020-8-25
djiuser_vRoALtlXpY3j
Sri Lanka
DJI Mindy Posted at 1-2 01:38
Hi! I'm also having the same problem
2020-9-19
SnowFoto
I am having the same problem how can I fix it please. I have a shoot tomorrow and now my gimbal is not working at all
2020-11-26
Kenji Bartolome
Philippines
I am having the same problem with this. How can I fix it.
2020-12-3
djiuser_fF5eBUOajJSB
For the love of all things good, does DJI have a solution to this? Autotune is timing out on me, and I'm getting the same message of "no roll/pan axis ESC data. Contact DJI Support."
2020-12-9
Jason Johnson9
laurenceplevin Posted at 2020-1-2 03:03
[view_image]
I have the same issues in my stats
2021-4-5
Lemonitus
Yep just started happening to me after updating the latest firmware.
Sending it back to my reseller isn't an option for me.
Is my only option sending it back? Gimbal works fine for 3 - 4 seconds then reverts to "No Pan Axis ESC data" every time which makes me think this is a software problem.
2021-4-18
fans83cee706
I have the same problem, what also happens to me is that it performs movements only after being a few minutes without activity, as if it were in "Push mode" this option is not activated ... What I have realized that it fails when the mode 3 is set for 3D. If you remove 3d mode it usually works fine for a while and then the problem returns. ... it's clearly a firmware issue, please Dji technicians fix it
2021-5-12
luccagporpino
Brazil
Same to me. Also DJI support doesn’t answer my tickets /: Anyone succeeded?
2021-6-14
tomsmdt
Flight distance : 566768 ft
I have the same problem. Turned on my Ronin S and instantly stopped working. I did not update the firmware since march and used it only a few times since then. Is there any solution to this problem?
2021-8-5
FATSO
South Africa
Adam.from.Maine Posted at 2020-2-8 09:45
How was the issue resolved?
2022-3-30
FATSO
South Africa
2022-3-30
sivak
India
Hi All,
        I  am having same issue now. Any solution for this please
2022-11-11
djiuser_VmGs1Q0KYot8
Philippines
[view_image]
How did you fix it??
2023-9-17
DJI Susan
Hi there, sorry that this issue can not be fixed remotely, you may need to send the gimbal back for repair.
If you are located in the Philippines, you may try to contact your reseller directly for assistance. You can also contact our support via email at support@dji.com for further guidance. Thank you for your understanding.
2023-9-18
