Koelkop
Flight distance : 22814806 ft
South Africa
DJI Tony Posted at 8-25 16:13
Hi, we're sorry for the inconvenience. May we know if this particular problem occurs every flight? You may try to follow the suggestion below to see if there will be changes. However, if it would still persist, you could send the unit into our facility or with one of our recommended service centers to check the aircraft thoroughly. For additional information, sending the unit to our facility would cost for repair as the aircraft's warranty has been voided in any case that it's still within the warranty period. If you wish to contact our support, please click this link: www.dji.com/support
* Change cable and location
Hi Tony
Thanks for the response, sending the drone in is too expensive and its past its warranty already hence why I fixed the ribbon cable myself.
It does not occur every flight. Maybe once in every 5 to 10 flights
By cable do you mean between phone and remote? The glitch shows on the main video not just the video feed.
I can try another SD card
Firmware is up to date |
