Inspire 2 + X7 camera gimbal
1913 13 2019-8-25
droneloverpilot
Flight distance : 64767 ft
Hi guys.
At the moment i have and Inspire 2 drone in combination with a zenmuse x7 camera. (9 months old)
Untill last week everything was working fine.
Today i assembled everything and wanted to to fly drone when i noticed that i was no longer getting video feed from my X7.
Gimbal seems to be working fine i can use my stick to rotate and jaw the gimbal without problem but there is somehow no feed.
Even when i try to enter the video settingens everything is grey and cant adjust anything there.
All firmware is up to date.
Can some one pls help me with this. Thank you in advance
2019-8-25
Flo the Pirate
Austria
reseat lens into gimbal and gimbal into drone
check pins between on gimbal and drone for dirt or damage
2019-8-26
droneloverpilot
Flo the Pirate Posted at 8-26 02:29
Thnx for the reply,
I tried that but without any results :S
I even reseted firmware to factory and updated everything from scratch. Tried running it on I pad to but still same problem.
https://www.youtube.com/watch?v=UjRil91I0uc&feature=youtu.be
this is a video i made showing the problem.
2019-8-26
ElectricLife Atellani
Flight distance : 9674836 ft
What remote controller / screen combination are you using?
2019-8-27
droneloverpilot
ElectricLife Atellani Posted at 8-27 08:44
At the moment using standard model remote with sammsung s8 phone. Everything was working perfect for 3 months untill last week.
Since than i even tried it with ipad and iphone atill no result
2019-8-27
droneloverpilot Posted at 8-27 13:41
I am sorry for that. I thought it might have been the cendence, which sometimes can become loose where it attaches to the screen and lose connection. I guess it's not the case.
2019-8-27
droneloverpilot
ElectricLife Atellani Posted at 8-27 14:29
Since nothing seem to help i send itnto dji for warranty. I will post an update once i get it back.
2019-8-29
Flo the Pirate
Austria
droneloverpilot Posted at 8-29 01:51
i once had the same problem , gimbal was working but no video so I took off the vibration plate with gimbal mount and i could see one hair thin cable got ripped - to tiny to solder for me so the whole vibration plate had to be changed
2019-8-29
droneloverpilot
Flo the Pirate Posted at 8-29 04:00
Could you maybe show a picture of what you mean? Any idea how that did hsppen btw?
2019-9-10
droneloverpilot
Do You mean this unit?
@dji how on earth can you make that connection cable so fragile? It should have some protection...
2019-9-10
Flo the Pirate
droneloverpilot Posted at 9-10 03:07
i pm´ed you a link , did you see that ?
2019-9-10
Flo the Pirate
ups sorry no pm to you ... mixed u up with someone else ....
yeah it´s that part ! when you look under the round plastic you will see even thinner cables going to the pcb that connects to the gimbal. one of those broken - it´s kind of easy to open that up and have a look
2019-9-10
Flo the Pirate
also note : i didn´t replace the vibration mount myself as one of the connectors goes right into the i2 brain that need alot of disassembling to get there - dji fixed that for me
2019-9-10
droneloverpilot
Ah thank you I will check it out when I am home today and will update accordingly
2019-9-10
