JDVideo
djiuser_SGtX4I7iJci7 Posted at 9-7 06:22
I’d expect a new version of the OP instead of updated accessories, although I like your thinking. That said the feel of the wheel, to me anyway, is better than the joystick on the extension rod.
I wish you could change the wheels direction though, I always manage to turn it in the wrong direction, particularly the up-down direction.
I'm going to order the control wheel, but I will most likely make the same sort of adjustment error. I don't particularly like the idea while filming a clip that wanting to pan up, while in the switch is in horizontal mode, I have to activate the switch causing possible bumps/vibrations in the video in doing so. Whatever transitions one does, it must be smooth. Flicking a switch each time will not allow that. Again, just a thought. I will see for sure once I start using it. |
