Missing Photos on SD Card
1574 12 2019-9-15
RDPhoto3
Flight distance : 90686 ft
P4P started acting weird when taking photos. This is a two year old  bird and I have plenty of experience doing photography with it.
In Photo Mode and Not Video Mode - The last  two times I have had it out and tried to take a photos with It acted  like it took the photo but when I got the card out and looked their was  maybe only one or two pictures on there. Should have been a lot more.
It  makes the shutter sound. I noticed the the focus was sluggish or I had  to try twice to focus. This was outside and on a bright day.
The SD Card I am using is a Sandisk Extreme Plus 32G U3 V30 (Red/Gold) Color.  Have been using this card for over a year and never a problem
before.
2019-9-15
RedHotPoker
Flight distance : 165105 ft
Maybe the memory card has gone bad, try a different SD card.
RedHotPoker
2019-9-15
DJI Stephen
Hello and good day RDPhoto3. I am sorry for the trouble this has caused. Have you tried using a different micro sd card or try to format the said micro sd card to see if the issue will persist? Thank you.
2019-9-15
Geebax
When was the last time you formatted the card in the aircraft?
2019-9-15
rwynant V1
Flight distance : 4842277 ft
Geebax Posted at 9-15 13:44
That's certainly a possibility.
My associate has had his P4P for over 2 years as well.....with all the mapping, and 100s of thousands of pictures taken......he has had to replace his camera TWICE.
We did a College campus parking lot site survey on Thursday the 12th.....my bird took 3,592 images.
And thats just 1 job!
In June we did a 3d Mapping job for a rail line in San Diego.......our total picture count was 8,254 between 2 birds.
My point being,  his issues with the camera started with missing images in his maps......
Randy
2019-9-15
Geebax
rwynant V1 Posted at 9-15 17:08
Yes. Most people are not aware that the aircraft automatically creates several hidden folders filled with unproductive information and also images, and because the folders are hidden, you are not aware that the card is filling up with crap. The only remedy is to format your card every now and then (I do it every 5 or so flights) and that clears all that information off the card.
2019-9-15
Labroides
Flight distance : 9991457 ft
Have been using this card for over a year and never a problem.
Have you checked the SD card in your computer and see how much free space is on it.
2019-9-16
RDPhoto3
Labroides Posted at 9-16 04:31
I am not sure it was the card.  I noticed that when I pressed the shutter button on my iOS device it will not take the picture consistently.  If I hit the button on the RC it works everytime.  This is intermittent problem.  For now I have tried a different card and will continue to test to see if it is the card or something else like DJI GO4.  I am using an iPhone Xs.
2019-10-13
Geebax
RDPhoto3 Posted at 10-13 06:10
First issue is the card, the  Sandisk Extreme Plus is only on the borderline of being fast enough for the job, the  Sandisk Extreme Pro is the better card. Second, as I suggested earlier, format the card in the aircraft.
2019-10-13
RDPhoto3
Geebax Posted at 10-13 13:03
Gotcha,  I will get the Pro Card and try it.  I flew the other day and noticed the behavior was still there.
2019-10-23
RDPhoto3
And I format the card in the aircraft often.  I download images to computer.  Then I put it back in aircraft and next time I fly I format card first.
2019-10-23
RDPhoto3
Which Extreme Pro card is the one I am looking for?  Seems to be a few different flavors of it when searching.
2019-10-27
Geebax
RDPhoto3 Posted at 10-27 03:34
One that looks like this: https://www.amazon.com.au/SanDis ... 2207937&sr=8-15
2019-10-27
