8-pin plug that connects the damping plate
6308 8 2019-10-2
FrankCohen
Flight distance : 266 ft
I have a Mavic Air. I bought it about 8 months ago. It worked great. No big crashes or anything broken. I did the recommended upgrade today and now I see the IMU will not work and I get a bunch of error messages, including one that says "Check the 8-pin plug that connects the damping plate and the aircraft."
I researched the problem in the DJI Forums, on YouTube, and with a Google search. I found no definitive answer.
I used the DJI Assistant application on my MacBook Pro to reinstall the firmware on the Air, on the Controller, and made sure I am running the latest app on my OnePlus 5 Android phone. Same behavior as above.
I use the DJI Go 4 app to recalibrate the gimbal. The camera moves around from place to place. The warning message in the app says the calibration is at 10% and does not change from that value.
I try the IMU Calibration by pressing the Start button. No reaction to the button press.
See the attached screen shots for details on what I am encountering. I would love to use my Mavic Air again, and soon.
Thanks for your time.
Frank
2019-10-2
DJI Gamora
Hi, thank you for bringing this query for us and we're sorry for the inconvenience caused. Can you please clarify if what recommended upgrade did you perform today? Is this a firmware update? If yes, you may try to refresh the firmware using the DJI Assistant 2 to see if the problem persists. Also, please make sure that you place the aircraft on a level surface when calibrating the IMU. You may refer to the tutorial below for you to properly calibrate your IMU. Please keep us posted. Thank you for your kind and understanding. Cheers!
2019-10-3
FrankCohen
Thank you for the reply. I performed the firmware update. That seems to have started the problems I encountered. On your suggestion I used DJI Assistant 2 to refresh the updates on the Air and the controller. Both show up-to-date, as they did before. I calibrated the IMU on a level surface.
I spoke with DJI support and they issues a service order. I used UPS to ship the drone today.
-Frank
2019-10-4
zottel
Any news? I have the exact same problem with my drone...
2019-11-11
Pataz
Belarus
Same problem. Need help
2020-10-16
Hello_Hubert
Hello,
I have exactly the same problem.
Can you help me?
Thank you
2020-11-15
Hello_Hubert
2020-11-15
Hello_Hubert
2020-11-15
Hello_Hubert
Hi,
I found the solution and i fix my mavic air.
Mavic Air : MAIN CONTROLLER DATA ERROR
https://youtu.be/Rd92rb2OtUM
Method to fix the mavic:
https://youtu.be/0Hs3ovtQG8A
Hardware:
https://drone-parts-center.com/produit/dji-mavic-air-imu/
Or search "Dji Mavic Air Imu" on Google and find a saler.
I fix my drone and it works !
2021-6-12
