First Flight with Mini, but lost signal at low altitude
1888 13 2019-11-30
Xmcaz
Flight distance : 14570 ft
Israel
My first flight was in the park in the evening, in the distance and low altitude there were no disturbances
but when I stood close to the mini and just checking height, it lost a signal at a relatively low altitude 24m
yellow lights flashed, and the video on display lost signal, so I had to land.
of course I raised the maximum Altitude / Distance before, to more then 50 m
But it didn't reach 50 either
Could the high antenna in the park have restricted the signal?
I've attached a video (the height I can, it's only up to the park antenna height)
Or should I switch setting to Manual and choose a cleaner channel?
(was set to auto)
2019-11-30
Gu5s
Flight distance : 284728 ft
Czechia
I found it confusing, that manual channel selection for both 2.4/5GHz is a single UI element... I was trying to figure out, how to switch from mode 5Ghz to 2.4GHz (the interface showing you the active mode is a passive projector - not an interactive element) only to realize both of these mods are mixed together at the channel selection... - Manually switiching to 1-13 (2.4 Ghz) - suddenly allowed me to go over 700m away without a problem instead of 50-70m right above my head in 5Ghz mode.
I think the best would be to allow "Auto channel selection", but let us select preffered mode... Maybe with future updates. (Or did i miss something?)
2019-11-30
Xmcaz
Israel
Gu5s Posted at 11-30 05:10
I found it confusing, that manual channel selection for both 2.4/5GHz is a single UI element... I was trying to figure out, how to switch from mode 5Ghz to 2.4 only to realize both of these mods are mixed together at the channel selection... - Manually switiching to 1-13 (2.4 Ghz) - suddenly allowed me to go over 700m away without a problem instead of 50-70m right above my head in 5Ghz mode.
how can i switch to 5.8? i can see only the 2.4 option (i have CE version)
2019-11-30
Xmcaz
Israel
By the way, I was on 2.4 and could only raise up to 24m height
2019-11-30
Gu5s
Czechia
After changing to manual, just click one of the channel column (indiciating interference) to swith on it
But 24m on 2.4 is weird... Must be reeeeeeally busy area...
The only advantage of 5.8 is
Less used frequency in general
Higher bandwidth (although not really important for drone flying anyway IMO)
The CONS of 5.8
higher frequency means shorter wavelength, means worse signal penetration and distance
5.8 mode seems to be made as a backup for short distance in highly 2.4wifi overpopulated areas.
2019-11-30
hallmark007
Flight distance : 10017858 ft
Xmcaz Posted at 11-30 05:13
To switch manually just change to manual select a channel for either 5.8 or 2.5 your app will auto shut down and start up again and you will stay fixed to channel you selected .
2019-11-30
Xmcaz
Israel
Gu5s Posted at 11-30 05:22
After changing to manual, just click one of the channel column (indiciating interference) to swith on it [view_image]
Thank you, i will test it in my next flight
Is there a situation that the antenna in the park blocked the range?
because once I reached the end of the antenna at altitude I lost the signal (24 m)
Next time I'll check in an open area
2019-11-30
InspektorGadjet
Flight distance : 439915 ft
Xmcaz Posted at 11-30 05:33
Yeah maybe test in a bright situation, if it´s too dark and downwards vision sensors cannot see, it may be affecting the height.
2019-11-30
marktottymy
Flight distance : 91860 ft
InspektorGadjet Posted at 11-30 07:07
I had similar issues and sent mine back for a refund/replacement.....
2019-11-30
Xmcaz
Israel
marktottymy Posted at 11-30 07:22
I need to try another flight, then i will know if there is a problem or not
I will also try to turn off the 4G internet which was active, and switch to Flight mode
(I read some of the other posts)
If they replaced to you the mini, it solved the problem?
2019-11-30
InspektorGadjet
Xmcaz Posted at 11-30 07:25
Yes try turning phone to airplane mode and turn wifi off too.
Keep us posted.
2019-11-30
RobertoCorrales
Hi Xmcaz, did you sort it out or found a fix?
2020-1-16
RobertoCorrales
Xmcaz Posted at 2019-11-30 07:25
Did you find a solution?
Thanks
2020-1-16
Xmcaz
Israel
RobertoCorrales Posted at 1-16 07:27
Thanks
Yes since the problem I checked again
It's not a problem in the end.
just needs to turn on Airplane mode on phone, it's help.
my next flight were in place without trees or big antennas I reach 100 meter height
This means that it depends mainly on the place itself.  Otherwise, the signal will not be good
2020-1-16
