chrisgeigerphot
Flight distance : 13046529 ft
I've done hundreds of 360 pano shots working for Google. In those shots, working in tight spaces it is very important to rotate around the lens no parallax position and I used a special tripod mount to do it. When doing aerial pano shots you don't need nearly as much accuracy. The further away objects are the less you see stitching problems. Here is a 6 shot pano taken with an RX100 with a Naza V2 controlled S900. Due to high wind I had about 3' of movement of the aircraft as I turned to get the photos. It still stitched fine in photoshop. Shots were taken at 300'. The man made lake is 1/2 mile long. The gimbal is not an issue for Parallax issues, aircraft movement will have far more effect on the shitchability.
I lookforward to doing multi-photo pano shots with the inspire. I think it will work great.
