Smart controller crashes application 4.3.25 during flight
3585 13 2019-12-25
Gjuro
Flight distance : 1051375 ft
Croatia
does anyone have a crashing DJI GO 4 v.4.3.25 application on a smart controller version of software .530  during the flight.
I noticed that I do not have a flight log when this happens, instead of having approx.24 min. controller recorded only part of the flight from restarting the DJI GO application until the end of the flight.
2019-12-25
DJI Paladin
Flight distance : 318 ft
Hi. I am sorry for the trouble this has caused. With regards to the said issue. I would recommend to please try refreshing the firmware of the DJI Smart Controller using the DJI Assistant 2 to isolate the issue. In addition, I will be posting a link ( https://www.dji.com/smart-controller/downloads  ) for the DJI Assistant 2 and an official DJI video tutorial for the said process. Please keep us posted for further assistance. Thank you.
2019-12-25
dronie1965
Flight distance : 24897940 ft
What mini sd card did you put inside the sc? How many gb card?
2019-12-25
Gjuro
Croatia
The problem has appeared on the last three flights, by then everything was fine (min. 15 flights was fine)
2019-12-26
Gjuro
Croatia
Only DJI GO crashes, usually it happens after 20 min of flight, I restart the application and it works on, the controller works all the time.[color=rgba(0, 0, 0, 0.87)]I reset the controller to its original settings and reinstalled dji go 4.3.25 from the sd card
2019-12-26
dronie1965
Inspite what the dji manual says , 64 gb sd is ok , you should put a 16 or 32 sd card in. I had same problems as you . After i put the 32 gb in , 6 months ago , i never ever had this problem
2019-12-26
Gjuro
Croatia
I'll try it. thank you
2019-12-26
Gjuro
Croatia
dronie1965 Posted at 12-26 03:29
I did one flight yesterday with a 32 GB memorry card and had no problems
2019-12-29
dronie1965
Gjuro Posted at 12-29 23:40
Thanks for letting me now that it works. I had the same problem before with a 128gb and 64 gb card.
With the 32gb i never had a problem anymore
2019-12-30
dronie1965
Somehow i am also not so happy with this .25 version app as it was never officially introduced via the normal update  way on the sc , therefore i still have .16 and that works so far brilliant.
2019-12-30
Gjuro
Croatia
the size of the memory card certainly has something to do with the problem I mentioned in the original post, as I did three more flights with a 32GB card in SC without any problem
2020-1-1
akozc
Flight distance : 2019951 ft
Macao
size of the MicroSD card???
well I am using Scandisk 128GB A2  V30 Pro Extreme ,which is one of the high speed card in the Scan Disk family.
Disconnection or sudden shutting down of the App may not related to size of the card but your accumulated cache files. I get used to clean the cache files before each fly and having no problem at all.
You may try
1) use Hight speed Micro SD
2) regularly / frequently clean the cache files.
2020-1-5
Gjuro
Croatia
akozc Posted at 1-5 08:24
I think you're right, because it happened again with this smaller card.Thanks for your suggestion
2020-1-5
Gustavo Buenrostro
Mexico
DJI Paladin Posted at 2019-12-25 13:09
https://www.youtube.com/watch?v=7tnlBifYD8E
I have done all of this to my smart controller and the dji app keeps crashing and the controller turn it self off, as a matter of fact I almost crash the drone twice because I can do anything with it while the controller is off and the drone keep on motion, I just recently purchase this drone MAVIS 2 PRO WITH SMART CONTROLLER,  and also stops recording every time that happens, what can I do ?
2021-2-5
