Speed to turn the drone is too fast
3523 8 2019-12-29
Timoune
Flight distance : 31089 ft
Hi,
When I film with the mavic air, the speed when i turn left / right is a bit too fast so it does not look nice.
I am a bit lost with the yaw / pitch speed. Which one is the one to adjust?
I think a smaller speed would be better for cinematographic moves.
Thank you!
2019-12-29
lannes
Flight distance : 4465 ft
In expo, I use these settings for smoother controls
throttle 0.25, rudder 0.20 and forward/backwards 0.25
This explains expo settings, lower number makes the sticks less sensitive
http://fromwhereidrone.com/drone ... er-movements-guide/
2019-12-29
DJI Stephen
Hello and good day Timoune. I am sorry for the trouble this has caused and thank you for reaching out. You can try to adjust the sensitivity of the your DJI Mavic Air by using the DJI Go 4 application. All you need to do is Launch the DJI Go 4 then go to General Settings > Main Controller Settings > Gain and Expo > Sensitivity. Thank you.
2019-12-29
Timoune
DJI Stephen Posted at 12-29 11:08
Thanks! And for the sensitivity, which one is the good one to adjust for my issue?
Thank you!
2019-12-29
cutis
Flight distance : 1695351 ft
Yaw means rotate about vertical axis hovering horizontally
Pitch means bow to stern rocking motion
Roll means port to starboard rocking motion
Now another yaw comes in during "rolling leftwards port or rightwards starboard"
Sensitivity, Gain, Brake, these tailor the integrated coexistence amongst the aforementioned.
How do you know you've got it on the money?
Try observing what it does when the sticks are released immediately after commanding any combo stick manuvering.
The drone must cease motionless.
How responsively it occurs is the importance.
After acquiring the matched set of prescriptions, only then would you tweak incrementally by single factor alone and eval perform.
2019-12-29
lannes
Timoune Posted at 12-29 11:29
Thank you!
Or you can use tripod mode
https://www.dronegenuity.com/5-b ... ligent-flight-mode/
2019-12-30
Timoune
Finland
Hi Iannes,
Thank you. Yes, this is also a solution that I did not try. But I don´t really want to be limited with the speed.
What i would like to do is just to change the sensitivity to turn left / right to have better movements in the videos.
Thanks for the help!
2020-2-17
oxid8ter
Flight distance : 20935 ft
lannes Posted at 2019-12-30 01:42
https://www.dronegenuity.com/5-best-uses-for-dji-tripod-mode-intelligent-flight-mode/
or cinematic mode, i believe that also makes the sticks less responsive.
2020-2-18
FanOfFlight
Flight distance : 1983760 ft
Timoune Posted at 2-17 00:03
Hi Iannes,
Rudder or Yaw,  I cant recall whats exactly is called in the expo settings for Mavic.
Google some you tube videos about setting the expo values.  Expo values dont slow down / speed up the movement they change how much is applied at what specific point your stick position is.   basically its a acceleration curve.  If you move the position to for example 20%, the expo curve could give you only 5% power.  Thats what your setting.  Full stick movement is still 100% power for that direction.  Learn it, before you adjust it so you know what it does before you fly.
2020-2-18
