Can use huawei or other brand which higher charger 40w?
2161 7 2019-12-29
bernardren07
Flight distance : 48504 ft
Singapore
Hi. I will like to know if can use huawei or other brand charger which higher 40w to support mavic mini hub? I seen hub support min 18w.
2019-12-29
DJI Stephen
Hello and good day bernardren07. Thank you for reaching out and for the inquiry. I hope that you will get the best recommendation from our valued DJI co pilots who uses the said charging brick on there DJI Mavic Mini. In addition I will be posting the specifications for the recommended charger for the DJI Mavic Mini. Thank you and please fly safe always.
2019-12-29
bernardren07
Singapore
DJI Stephen Posted at 12-29 16:28
[view_image]
ok. If i buy huawei super charger which 40w higher. it will not damage mavic mini hub and and remote?
2019-12-30
Alevpi
Flight distance : 43560 ft
Russia
bernardren07 Posted at 12-30 04:59
And here the power of the charger, the controller of the charge consumer himself asks the charge current he needs, it is bad when he asks, and the charger can not give him the necessary charge current. I use BlitzWolf BW-PL2.
I bought another Baseus 65 W and will use it as soon as it is delivered.
2019-12-30
DJI Stephen
Thank you for the additional information given bernardren07. With regards to using the Huawei super charger with 40w. I would suggest using a recommended charger for the DJI Mavic Mini for compatibility and reliability purposes. There is a possibility that the said charger will be able to work on the DJI Mavic Mini battery. But however, since it's not yet tested by DJI we cannot guaranteed if it will work all the time and if it will charge the battery properly with no issues. Thank you for your understanding and support.
2019-12-30
JodyB
Flight distance : 302536 ft
I use this "unsupported" charger and therefore can not claim that it will do the same for you. With that disclaimer out of the way, it has a total of 6 USB ports. 4 can charge at 2.4 amps each. Your basic charge port. The other two are quick charge 3.0 ports. Each capable of providing independent charging of two QC 3.0 devices at the same time. If you consider something like this, you just want to make sure you order one that meets your electrical standards, IE USA plugs verses plugs for your area. Again, this device is not on the official supported list. I have had mine for about a week now and I charge both the battery hub and the controller at the same time and both fast charge beautifully. Also has the added benefit of reducing the number of charge bricks needed at one time.
https://www.amazon.com/gp/produc ... 0?ie=UTF8&psc=1
2019-12-30
bernardren07
Singapore
JodyB Posted at 2019-12-30 11:25
https://www.amazon.com/gp/product/B07P8V7ZDN/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
ok thank you alot. i bought it and charge quite fast.
2020-1-3
JodyB
bernardren07 Posted at 1-3 23:32
It’s a nice little piece of kit isn’t it?? I love mine!!! And yes it’s pretty fast too!!
2020-1-3
