Vital Info When Unlocking Geo Zones
1208 12 2020-1-3
Bigplumbs
Flight distance : 620164 ft
I successfully unlocked using the new firmware and the 1.0.4 App on day one this lasted 24 hours. On Day 3 I had to unlock again and it said unlocked but the red light was still on and it would not allow takeoff..... The issue was that my phone signal was only 3g and not up to the job of connecting to the internet.
So in simple terms if the Tablet or phone you are using as a screen is not connected to the internet it will not unlock even though it says it has.
If you are going somewhere where you might need to unlock a zone but the internet connection might be bad look on the DJI fly safe website and unlock their before you travel. This unlock lasts 72 hours from midnight on the First day you select.
Also remember that the flight controler Seriel number is the one you need to input on the website not the Remote control (RC) seriel number.
It is also important to arm the motors by the 2 sticks in a down methob dont use the lift off icon on the screen.
Hope this helps and saves someone a wasted Journey
2020-1-3
marktottymy
Flight distance : 91860 ft
Another issue is the AC serial number, I have 2 MM and the app reports the AC serial number incorrectly on both. I am still experimenting with the MM Self Unlock, and still not sure if the incorrect serial number allows actual unlocking. If you want to know what DJI sees as your serial number, you can see it under devices in the DJI store app...
2020-1-3
stubbietubbie
Flight distance : 119288 ft
Definitely helpful info for me when I go out, the phone reception is patchy at best so this'll be very handy. Cheers.
2020-1-3
Bigplumbs
marktottymy Posted at 1-3 03:44
It is not the AC Serial number you need it is the Flight Controller serial number
2020-1-3
JodyB
Flight distance : 302536 ft
Bigplumbs Posted at 1-3 09:10
Bigplumbs is right, it;s the flight controller serial and not the AC serial that you need.
2020-1-3
Bigplumbs
JodyB Posted at 1-3 09:24
Bigplumbs is right, it;s the RC serial and not the AC serial that you need.
I am afraid you have added confusion. to be clear...…
The RC (Radio Control unit with the sticks) …………. It is not this one
The AC (Aircraft) ……….. It is not this one
The FC (The Flight Controller) Inside the drone you cannot see this.... THIS IS THE SERIEL NUMBER YOU NEED. THIS IS SHOWN IN THE ABOUT SECTION IN THE APP
2020-1-3
JodyB
Bigplumbs Posted at 1-3 09:36
Corrected, thanks for pointing that out. Was in a hurry and mixed the terms.
2020-1-3
spanzetta
Flight distance : 1124738 ft
JodyB Posted at 1-3 09:39
it's crazy that there is so much confusion about serial numbers
I did open a post about that
https://forum.dji.com/forum.php? ... 205601&mobile=2
2020-1-3
JodyB
spanzetta Posted at 1-3 10:21
https://forum.dji.com/forum.php?mod=viewthread&tid=205601&mobile=2
It can definitely be confusing for sure. That why we try and help each other out though.
2020-1-3
InspektorGadjet
Flight distance : 439915 ft
Thanks for clarifying definitely some confusion regarding all the SN...
2020-1-3
DJI Paladin
Flight distance : 318 ft
Thank you for sharing this informative post. This will help our valued DJI co pilots unlock their drones when flying in a " No Fly Zone " . Thank you for your valued support.
2020-1-3
lprising
Flight distance : 32402 ft
When you go to the unlocking step, the window on the left side actually shows you the FC Serial Number to enter. You don't even have to look it up.
2020-1-3
Bigplumbs
lprising Posted at 1-3 16:55
Many thanks I did not see that
2020-1-4
