First crash and lucky recovery
630 10 2020-1-19
ERC
Flight distance : 608629 ft
Today I crashed the mini for the first time, hitting an overhanging tree whilst flying over a reservoir.  After much panick and running around, just as I was about to give up and walk away, I found the mini up against a tree.  I am trying to recover the footage of the last flight (the crash), off the SD card but I am unable to open it and can see that there is no codec information on the mp4, is there anyway to recover the file?  I'm guessing it did not finish processing when the mini powered off!
2020-1-19
Minnesota
Put the card back in the drone, begin another recording, and it should close out the prior file.  Then it should be good.
2020-1-19
DowntownRDB
Flight distance : 1722 ft
Glad to hear you found your MM.  Hope it didn't sustain any damage.  Be sure and inspect your propellers closely before you fly again.
2020-1-19
DJI Stephen
Hello and good day ERC. I am sorry to know what happened to your previous flight with your DJI Mavic Mini. Since there was a crash that happened and if you feel that your DJI Mavic Mini is not performing well on your next flight. It is best to contact our DJI Support team at https://www.dji.com/support?site=brandsite&from=nav for us to be able to check the said drone. Thank you and please fly safe always.
2020-1-19
ERC
Minnesota Posted at 1-19 04:10
Thanks, that worked but weirdly the SD card clip is 8 seconds shorter and does not show the crash like my cached version on the phone.
2020-1-19
ERC
DowntownRDB Posted at 1-19 05:18
Just inspected and the only damage is slight on the battery case, the propellers are fine and it is flying ok.
2020-1-19
InspektorGadjet
Flight distance : 439915 ft
Wow glad you found it!
2020-1-19
Lucas775
Flight distance : 50642090 ft
Glad everything went well.
2020-1-19
BobWinNV
Flight distance : 300837 ft
View the video from fly app and it will then close it properly and you will be able to view it from your computer.
2020-1-19
DowntownRDB
ERC Posted at 1-19 08:47
ERC, great to hear it was only slightly damaged and only a battery case.  Really lucky.  With your luck today you might want to go buy a lottery ticket or two.  LOL.
2020-1-19
ERC
DowntownRDB Posted at 1-19 12:07
Yep very lucky! I started to walk away because I was adamant it was in the water.  Here's the final moments of the crash...
2020-1-19
