DJI Air unit video loss
2806 10 2020-2-6
Zhiran
Flight distance : 1061115 ft
Iraq
Hey DJI,
I have a problem with my current fpv drone which I lose video signal all of the sudden even in close range and medium range. It is been a month I contacted DJI support and they are still asking me random questions. I connected the air unit to the 9v power source on the flight controller. the problem is the video feed just blackout.
Here a picture of my setup: "I did more cable management, don't judge me"
Thank you for your recommendation and help.
2020-2-6
AntDX316
Flight distance : 3394731 ft
It says your location is Iraq.  There must be a lot of military-level jamming going on there so it is to be expected.
2020-2-6
Kreeze
Could be your 9v power source isn't reliable enough. You could look into adding a capacitor. Here's a video about it: youtube.com/watch?v=6FQbWWaEHxU
2020-2-6
Zhiran
Iraq
AntDX316 Posted at 2-6 18:45
I am sure there are more military level jamming in your whatever country is than my home town. I live in the north part of Iraq which is a totally different place we don't have any military activities.
2020-2-7
Zhiran
Iraq
Kreeze Posted at 2-6 19:39
I thought the capacitor is required for 6s batteries, while I use 4s battery I didn't install the capacitor but I will connect the air unit to the battery directly.
2020-2-7
AntDX316
Zhiran Posted at 2-7 03:33
Well if you are in between military operations going on and the feed has to be solid, they will send like 50000W to keep the link as strong as possible stomping on all the signals within a certain band.
2020-2-7
Zhiran
Iraq
AntDX316 Posted at 2-7 04:03
It been three years I am flying p4p without any range problem. This doesn't has anything with military. Thank you
2020-2-7
AntDX316
Zhiran Posted at 2-7 04:12
They just started operations in your area but probably left so it won't happen again.
2020-2-7
mc54
Flight distance : 1030 ft
Were you recording on the air unit?  Is your air unit SD card fast enough?   This can cause video shut offs.  Try flying without an SD card in the air unit.
2020-2-7
Zhiran
Iraq
mc54 Posted at 2-7 09:32
Yeah, I was recording on both the air unit and the goggle, next time I will not put an sd card to the air unit and see what happens!
2020-2-8
djiuser_FWIYR3Ljq4jj
Zhiran Posted at 2020-2-7 03:34
you can do this as long as you dont use a 6s battery, youll fry it.
2023-2-25
