JJB*
Flight distance : 12477300 ft
Hi Peter,
Sorry for your loss!
Great area to fly, but not very good area for good gps reception.
You started your flight with jus7 7 satellites and 3 bar for reception. 4 is needed for HP set.
HP was set after 23 seconds in flight.
At 28 secs a warnings
"GPS signal weak. Positioning accuracy affected. Fly with caution", "Sensor Error"
GPS reception to 3, a GpsPositionNonMatch in the log.
At 43 secs GPS reception from 3 > 2 > 0, MM into OPTI mode ; so enough light and within OPTI height range.
MM keeps it postion now using the vision sensors. This for 3 secs , back to P-GPS as reception back to 3.
Again same messages about GPS ; GPS signal weak. Positioning accuracy affected. Fly with caution and Sensor Error.
But at 2m9s few times NotEnoughPower and warning "Aircraft max power load reached. Decrease altitude and fly with caution. If this issue persists, Land immediately"
Batt level 23% ; cell1 and cell2 at 3.3 Volts wich is a normal value. (AFAIK)
2m15 again in OPTI, back in P-GPS with same warnings about GPS.
From 2m18s MM dropping height [ uncontrolled ! ], Vertical speed of minus -2.6 m/s reduced to 0.2 m/s by pulling UP but too late to recover. (not saying too late taken action by you, MM slow in recovering descend).
What went 'wrong' ;
Always start to fly such nice tricky shot with a full battery. (but with 3.3 volts MM should react normal)
Be carefull in areas where GPS reception can go low.
With errors better stop flying than continue flying.
cheers
JJB
