Air unit video freeze
5744 14 2020-4-9
rydfree41
Flight distance : 153268 ft
I have a GEPRC Rocket Plus BNF that I received on March 24th .   All I had to do of course was bind the XF rx and go as it is sold as a professionally tuned BNF . It flys fine , although my flying sucks due to only getting the Mavic out for the past 4 years . The last thing I flew like this was an old Vortek 280 so pardon my not so smooth test runs here .  The onboard video will freeze as soon as I do a powerloop while the video still runs recording audio only . If I wait until later in the flight as in the link below , it will freeze at that point or it will freeze immediatly if I perform a loop just after takeoff . I have tried 4 different SD cards , all formatted in the Air Unit . Two are Sandisk Ultra with one being a 64 GB and the other a 32GB . The other two are 32 Gb Kinstons all of which do perfectly fine in the Mavic or a HD dashcam which I tried them in . Any help will be appreciated as GEPRCs support has been useless .  I'll tack their responses below .
Here is the GEPRC Rocket Plus  https://geprc.com/product/rocket-plus-dji-air-unit-hd-fpv/
A sample video from my 2nd flight . At 2:20 the video freezes but continues recording .
GEPRCs answer :
     [url=]info@geprc.com[/url] <[url=]info@geprc.com[/url]>
Wed, Apr 8,   3:28 AM (1 day ago)
to me
Hi
It is almost normal at the video
Might signal disturbance
Thank you
1:26 AM (3   hours ago)
to me
Hi
This is ok
Nothing bring effect the camera but disturbance in the video
Thank you
2020-4-9
mc54
Flight distance : 1030 ft
The fact that it only happened while under strain to the battery deep into a pack makes it seem power related.
I think your FCs 9V regulator powering your air unit is suspect, maybe it's not proving enough amps under load.
That's why I use an FC specifically designed to work with the air unit like the Kakutef7 HDV. Other FCs CAN work, but why through in extra variables.
2020-4-9
rydfree41
mc54 Posted at 4-9 05:49
It happens at the beginning of the pack also . Your theory makes sense but would not GEPRC be using a Fc that is designed for the Air Unit since it is a BNF ?  I suppose I'll tear it down and have a look but just kinda PO'd that GEPRC is just blowing my questions off .
2020-4-9
Tom_A
Flight distance : 899951 ft
rydfree41 Posted at 4-9 06:47
Does a punch out cause freezing, or just a power loop?
2020-4-9
Tom_A
2020-4-9
Tom_A
2020-4-9
rydfree41
Tom_A Posted at 4-9 08:00
Just a power loop . Everything else is just fine .
2020-4-9
djiuser_gNa3Emgkl5Rh
My brand new geprc hd3 air unit does the same exact thing? I'm trying to find solutions before I return.   Once said sd slow in goggles? But formatted two exact same cards sand disk ultimate 32gb works in Goggles? I wasn't shure does happens after power loop freezes.  Sometimes audio last for rest of vid. Going to try some different cards. Then get ahold of seller. Disappointed in product so far...see if dji backs??
2020-4-14
Cobaki
Switzerland
Had exactly the same problem with video freezing during power loops. I'm pretty sure my problem was a loose XT60 connection from the PDB to the battery causing a short brownout. I just spread the leads on the female connector and haven't had any issues since. Might be worth a try.
2020-4-15
rydfree41
Cobaki Posted at 4-15 00:58
Thanks everyone for the suggestions . I have been very busy lately and haven't had a chance to fly again . Hopefully this weekend I will fly and try a new Sandisk Extreme SD card . I saw that was on their website with the drone so I'll make sure I am using the same card . The support from GEPRC really sucks . I'll be sure to come back with the results of trying a few things .
2020-4-23
rydfree41
rydfree41 Posted at 4-23 08:56
Sadly the issue still prevails . New SD cards and latest Firmware and the video froze in 2 of the 4 flights .
2020-5-9
jedhassell
I am also having the same issue.  Also have GEPRC Rocket Plus and am using Sandisk Extreme card.  I believe it is only happening when in 1080p mode though.  Have you tried in 1080p and 720p?
2020-6-3
rydfree41
jedhassell@gmail.com Posted at 6-3 21:14
I lost all video in the goggles shortly after this and lost the Rocket Plus in a wooded area .
2020-6-4
fans353c5c0b
Flight distance : 325243 ft
My brand new Armattan Badger 4s with DJI Air unit (Caddx built - v2) freezes during a loop. I've only done 4 batteries on it. The first two, video froze and I crashed.
3rd battery.. I took it easy and I had a spotter... flew fine (just figure of 8s... no flips)
4th battery.. I decided to go for a split S. as soon as I pulled up.. video froze... I crashed. messed up my foam pads.
I then decided to let my spotter have the goggles and I flew it LoS.... everytime I pulled up for a loop... video froze
Cl Racing F4S 1.6 (Air Unit soldered on to the cam pads at 9.2v)
running latest firmware on goggles.. (1.0200.1 or something. 0606 or something on FPV Air Unit mode.
I'm tempted to solder the air unit direct to battery to test..
2021-7-21
fans353c5c0b
video of first crash which took me about 15mins looking for the quad as it fell on tall grass bushes and I had no idea where it fell so had to look around.
2021-7-21
