MIcroSD card
676 13 2020-4-29
Steve Woodmore
I am really struggling to find a MicroSD card that will allow me to record in 4k.
Currently using Sandisk Extreme V30 3 A2 64gb cards and as soon as I shoot in any resolution above 2.7k 25fps I get terrible audio lag and shooting in 4k 25fps or higher I also get vdeo lag.
Any suggestions?
2020-4-29
Woe
Flight distance : 4129268 ft
What are you filming on? I use the Samsung Evo 128gb in my cameras.
2020-4-29
Steve Woodmore
Woe Posted at 4-29 07:03
I did say in my OP.
2020-4-29
Woe
Steve Woodmore Posted at 4-29 08:25
I did say in my OP.
What are you using it in? OP OA MP2 MPZ ? You mention
the SD card but not what you are using it in.
2020-4-29
Steve Woodmore
Woe Posted at 4-29 08:31
I'm using it in an Osmo pocket, it's showing to me that I posted this in the Osmo Pocket Forum???
2020-4-29
Woe
Steve Woodmore Posted at 4-29 08:44
Have you updated the firmware? Also if you can post a video
that would help us give advice on whats going on and a possible fix.
2020-4-29
Ray-CubeAce
Strange.
I only use those cards with no problems at any setting. Do make sure you format the card in the Osmo Pocket before using though. Never delete indiviual clips but once uploaded format in camera to clear the card.
2020-4-29
Curt1591
Thailand
The reason this was asked is that so many can't seem to find the correct forum. There are many Mavic / Action and other device questions posted on the Osmo Pocket forum.
2020-4-29
Steve Woodmore
Ray-CubeAce Posted at 4-29 12:31
Strange.
I have the latest firmware, I have formatted it in the camera.
Just tried it in my SJ5000x  action cam and I am getting super smooth 4K  on it, so I guess I have an issue with my Osmo then.
2020-4-29
Curt1591
Thailand
Steve Woodmore Posted at 4-29 14:09
The SJ5000x is a GoPro knock off. Is it truly 4K?
https://www.cnx-software.com/201 ... video-test-pattern/
2020-4-29
Steve Woodmore
Curt1591 Posted at 4-29 14:37
https://www.cnx-software.com/2014/09/26/test-your-4k-device-true-resolution-with-a-4k-uhd-2160p-video-test-pattern/
Yes it really is 4K and I also checked the card in Mm Galaxy S9, again 4k is perfect on that..
2020-4-29
CemAygun
Flight distance : 810 ft
Philippines
The card you are using  is supposed to have around 90 MB/s write speed, Osmo Pocket only needs around 12.5 MB/s at it's highest (for 100 Mbps video). There is something else wrong here.
By the way  it is a very common mistake but technically speaking the video resolution has absolutely no bearing on the card speed required. The only thing that matters is the bitrate. As a rule of thumb the bitrate should increase along with the video resolution and/or frame rate (hence the misconception)  but this is not always the case. Mavic Pro records 4K at almost half the bitrate of Osmo Pocket for instance, so a much slower card would work on that.
If you want to clear the card, try it on something that records video at 100 Mbps (or more). If I am not mistaken S9 4K bitrate is much lower than that, and SJcam barely uses a fraction...
2020-4-29
Curt1591
Thailand
Steve Woodmore Posted at 4-29 15:13
Because its specs say so?
2020-4-29
Steve Woodmore
With absolutely no help at all from this forum or DJI tech support I have found the problem and the solution.
DJI tech support told me to return my camera for checking. No help there really.
The problem is indeed a DJI issue but it's not a fault withe the Osmo pocket and it's something that can be fixed in firmware if they want to bother.
Lets look firstly at the problem.
My mobile phone Galaxy S9 records in 4k, I can play those 4K files back on my PC
My action Cam SJ5000X records in 4K I can play those 4k files back on my PC
I recorded a 30 second clip on each and put all 3 in the same directory on my PC and it struck me, the problem was actually staring me right in the face.
The Osmo pocket 30 second 4K file was over 5x larger than the other 2 files  FFS it's the codcec they are using, for want of a better word it's bloated.
It identifies as H264 but I suspect it's a customised version that DJI are using with a much larger than needed bitrate
The solution was so simple, import it into Adobe Media encoder output it as a H.264 35 mb/s Bitrate, job done, it now plays in 4k quite happily on my PC
2020-5-6
