Joecos
Flight distance : 3294770 ft
Inspire 2 Servo motor arm will eventually go bad due to age and wear and tear. But before we conclude to that, there are a few things to check ....
There is a setting in the DJI Go App - to keep the arm from going up. Make sure the setting is set to "Normal" (sorry, I am not in front of the controller / app settings to remember exactly where this feature is)
Once, the setting is set to normal or auto - and if the arms still wont lift up, then very likely the servo arm motor needs to be replaced and you can do it yourself as DIY or send to DJI for servo motor replacement. |
