GPS Metadata stored in image files
4103 6 2020-6-7
rth_images
I am trying to ascertain if Mavic 2 Pro sores the GPS metadata in its image files.  I have just spoken to your on-line chat and they said "no".  However, I have read other threads on here that indicate it does.  Which is it?  If it does, is there a setting in the DJI app that I need to enable this feature?  Because my Mavic 2 Pro does not appear to store this info.
2020-6-7
gnirtS
Flight distance : 5712575 ft
Full GPS and altitude data is in the metadata of all the DNGs taken.
2020-6-7
JohnDG
Flight distance : 1097270 ft
Belgium
Hi rth_images,
I find gps data in my raw-pictures from my Mavic 2 pro, which I got from the memory card in the drone.
2020-6-7
rth_images
OK thank you.  That means I must be undoing that on my import into Lightroom.  I found where I could have been doing that but wasn't sure if the data was actually there to begin with.  On import, because it is a DNG file, it can't be retrieved after LR bakes in the null field.
2020-6-7
gnirtS
rth_images Posted at 6-7 22:54
Works fine here in Lightroom with the DNGs.  Metadata all comes into the database (and exports on the jpg if desired)
2020-6-7
rth_images
Thanks - yes, I know where the problem is.  I have a metadata preset which applies on import and I've always had the boxes ticked and today I have discovered that it works in reverse to what I thought!  It has been, in fact, nullifying the data in those fields.  I have corrected the preset so that it imports the data in future.  I just needed confirmation that the data was actually in the file in the first place.
2020-6-7
rth_images
I thought having those boxes ticked, was telling lightroom to bring the data from the file in but it actually means - DON'T!
2020-6-7
