In m210 v2, video is not received according to the usb mode.
814 1 2020-6-24
nearthlab
Flight distance : 25125 ft
South Korea
m210 v1 and v2 are great products. However, there are some problems when used with manifold2.
On m210 V2(RTK, nonRTK both), The problem I encountered is that depending on the USB mode, the video(x5s) cannot be received at crystal-sky display.
1.When changing the USB mode to PC mode using the slide switch,
manifold can detect m210 USB / but, video from gimbal camera(x5s) not display on crystal-sky display with ERROR 'sd card is not enough'
2. If setting the USB mode to mobile mode,
manifold can not detect m210 USB / video display on crysta-sky display
but, on m210 V1 with same manifold it didn't happened.
Even if you connect the m210 and the computer (Linux), it happens again.
ofcourse i activated every flights, update firmwares/apps,  enable USB port to fly. there are enought volumes in SD card.
Are there any solutions to solve this USB mode problem???
2020-6-24
内涵阿哥
Flight distance : 791867 ft
China
This is not an error,   it related with the solution that designed.
USB mode  -   this means the camera storage would treat as a SD card or so,  no  live stream at this time since the ethnet is break.
ETH mode -  normally,  it would be this mode,  usb would be act as ethnet, the live stream can transfer normally.
2020-6-27
