PHANTOM 4 MS CRASH
483 14 2020-10-16
Ouriel
Flight distance : 155486 ft
Benin
Hello,
I don't know if somebody may help me to understand what happened to my P4M.
I've planned an automated mission with GS Pro and my drone take off reach the survey altitude (228ft) and then suddenly start coming down and crashed.
After reading logs i've noticed (GPS POSITION NOMATCH) error. I can't understand.
I'm sharing flights logs  here https://drive.google.com/drive/folders/1JMKnC3Nsu0ew5FpYk0N-cyU6t1utpsx8?usp=sharing
THis is the link of the viewer https://www.phantomhelp.com/logviewer/8QM64JUS31GW39EJOY3A
THANK YOU for taking your time to help me and sorry for my english
2020-10-16
Ouriel
Benin
P4M CRASHED
Hello,
I'm flights logs are here https://drive.google.com/drive/folders/1JMKnC3Nsu0ew5FpYk0N-cyU6t1utpsx8?usp=sharing
2020-10-16
Labroides
Flight distance : 9991457 ft
Your Phantom was in stable flight for the first 18.3 seconds but at 0:18.4 it tilted backwards, rolled to the right and started rotating anticlockwise and losing height.
In short time it was spinning, tumbling and falling fast.
This suggests that it lost either the back right prop or motor.
The GPS message is just a symptom of the GPS receiver having difficulty with the tumbling and is just a symptom, not indicating a cause of the crash.
2020-10-16
DJI Natalia
Hi there, I'm sorry about the accident. Please kindly contact our support at the link below to open a case and send the drone in, we'll submit a data analysis to find out the cause if the drone is under warranty. And we will provide you with the corresponding offer based on the analysis result.
https://www.dji.com/support
2020-10-16
Ouriel
Benin
Labroides Posted at 10-16 03:59
Thank you. Would you please tell me what you think that can be the reason of this? I'm trying to write the complete report of the crash and I do not have any clear information
2020-10-16
Ouriel
Benin
DJI Natalia Posted at 10-16 19:20
Hi. Thank you... I will
2020-10-16
Labroides
Ouriel Posted at 10-16 22:29
It was caused by losing an ESC, a motor or a prop.
If all props were still attached when you found it, we can eliminate the prop which leaves a hardware fault in either the motor or its ESC.
2020-10-17
Ouriel
Benin
Labroides Posted at 10-17 04:26
Thank you.
I thought It was ESC.....
2020-10-17
JJB*
Flight distance : 12260774 ft
Ouriel Posted at 10-17 07:55
Thank you.
Hiya,
At the end of your flight an error for motor #4.
if you like put a cloud link on here to the DAT [ FLY097.DAT *] file for this flight.
In the DAT more info to be found about your motors.
* on your mobile device ; MCDatFlightRecords map.
cheers
JJB
2020-10-20
Ouriel
Benin
JJB* Posted at 10-20 06:38
Hiya,
Hi,
THANK YOU for your reply.
there is the link for the DAT file
regards
2020-10-20
JJB*
Ouriel Posted at 10-20 11:25
Hi,
thanks, i can see it but cannot download the file.....after clicking on the download btn   nothing happend, uh??  never saw this before on a shared google map
oke, when i download both files as a zip   it does work!
2020-10-20
Ouriel
Benin
JJB* Posted at 10-20 11:32
Great..
waiting for your feedback after analyzing
one motor have damaged after the crash. that may be the reason of motor #4 errorone of propellers (the one attached to the broken motor ) couldnt also been found
2020-10-20
JJB*
Hi,
Hi,
Looks like that in this DAT file only date before motors ON are stored, so no flight data to be found.
cheers
JJB
2020-10-20
Ouriel
Benin
JJB* Posted at 10-20 11:56
Hi,
Hi I've uploaded the remains logs. please check if possible.
thanks a lot
2020-10-20
JJB*
Ouriel Posted at 10-20 13:54
thanks a lot
Hi,
Cannot find what i am looking for in your DATs, sorry cannot help you further.
Only in 1 DAT i find motor rpm, but all normal values.
cheers
JJB
2020-10-20
