CRASHED my Mavic Mini - help with errors
2749 16 2020-10-29
Eranglr
Israel
Hi,
I crashed my Mavic Mini and now it won't lift + getting errors (see photos).
I think that one of the proximity vision sensors is broken, am I right?
[size=0.83em]WhatsApp Image 2020-10-29 at 10.14.17.jpeg (70.52 KB, Down times: 0)
Download attach
Left sensor dead?
[color=rgb(153, 153, 153) !important]6 mins ago Upload
The GPS doesn't work out-side either.
Is it DEAD??
2020-10-29
DJI Stephen
Hello there Eranglr. I am sorry to read and to know what happened to your DJI Mavic Mini. Since there was a crash that happened and you are experiencing this issues after the crash. It would be best to contact our DJI support team at https://www.dji.com/support for further assistance. We have a team that will do there best to to check the said DJI drone and give out the best resolution for this issue. Again, I am sorry for the trouble this has caused and thank you for your understanding.
2020-10-29
Scarves UP
Flight distance : 372992 ft
Return to DJI.
2020-10-29
Eranglr
Israel
Scarves UP Posted at 10-29 05:48
Return to DJI.
How?
Crash was my fault.
2020-10-29
djiuser_rgkxLtpvRJuC
You can get a replacement drone if you have purchased DJI care refresh.
2020-10-29
Scarves UP
Eranglr Posted at 10-29 05:50
How?
Crash was my fault.
They will fix it with a fee. Less than a new drone (100-200$). Your drone is totaled, thats not flying again.
2020-10-29
JJB*
Flight distance : 12401030 ft
Hi,
Bottom sensor MM  ; one is sending, one is receiving, so no problem.
Red Warnings
GPS > try outside to get GPS reception,  perform IMU calibration if not oke, try again
Gyro > IMU cal, try again
BARO > IMU cal, try again
If errors persists,  uh, repair by DJI
cheers
JJB
2020-10-29
Suren
Flight distance : 13498560 ft
New Zealand
Try what JJB said and if all else fails send to Dji to fix
2020-10-29
djiuser_tSLgFPWAUIOe
Flight distance : 213648 ft
Hello,
My lost my mavic mini to on 10/04 celebrating my Aunt's 90th bday boating in a the Marina in Oxnard, CA. The drone was doing great, when it autohome when there is more battery life's left. Tried to disengaged to manually control and land it but the drone ascended to quick and flew away and landed where it was launched, unfortunately it was in the middle of the marina/water and lost. Is there a way I can get help analyze what happened? Thank you.
2020-10-29
Eranglr
Israel
JJB* Posted at 10-29 07:18
Hi,
[Image]
Thanks.
Problem is that it keeps disconnecting, so I can't manage to calibrate it.
2020-10-29
JJB*
Eranglr Posted at 10-29 09:37
Thanks.
disconnecting can be a mobile device / app issue....try different one ?
2020-10-29
Scarves UP
djiuser_tSLgFPWAUIOe Posted at 10-29 09:35
Hello,
Make a thread, no one will notice - help here. Most likely it was pilot error.  For help, post your flight log.
2020-10-29
Eranglr
Israel
JJB* Posted at 10-29 10:34
Probably not since before that crash everything worked with my device.
2020-10-29
Superfly-
Malaysia
Could it be the mounting point of the sensor, GPS and IMU component been displaced due to the shock when it's falling to the ground?
2020-10-30
Eranglr
Israel
Superfly- Posted at 10-30 02:06
Maybe, but that doesn't explain the disconnections.
2020-10-30
Superfly-
Malaysia
Eranglr Posted at 10-30 03:16
My heart goes with you and your craft needs to be hospitalised..
2020-10-30
Eranglr
Israel
Superfly- Posted at 10-30 03:34
thank you.
2020-10-30
