Cients
Flight distance : 5537369 ft
Portugal
Huginn Keningar Posted at 2020-11-26 16:02
Till now I was flying with WiFi and BT disconnected but 4G connected. Wifi signal interferes with the drone, you can notice it even in short distances (at least in CE mode). I was using 4G mostly to get the data for satellite map, but I realized that any incoming call or message in a bad moment can make you lose your drone, so from now on, airplane mode only. Also, not having the 4G antenna connected will reduce the interference.
You can cache the maps before the flight, just enter the map in Dji Fly (no need to turn on the drone), zoom in the area you want to fly and then it'll be stored i the cache, so when you turn airplane mode on you'll still have the map downloaded.
Hello Huginn Keningar!
Did you experienced that aircraft lost connection with RC when your phone had wi-fi connected, at short distance from 4 to 40 meters and at 1 meter to 15 meters high?
Thank you. |
