Accessories compatibility with Mavic Mini and Mini 2?
5710 8 2020-11-8
Juke
Flight distance : 207182 ft
Finland
I'm planning to upgrade from Mini to Mini 2.
Dimensions are almost but not excactly the same. Any idea what accessories, for example prop guards, lense filters etc are compatible?
2020-11-8
JohnLietzke
Flight distance : 3317608 ft
The charging base is not compatible.  The original Mini use micro usb and the Mini 2 uses USB-C.  I saw that the prop guards do not work with the Mini 2 but the source online was using a version specially made for use in Japan.
2020-11-8
Renato61
Flight distance : 168163 ft
Lens filters are compatible.
2020-11-8
Seisiuneer
Flight distance : 20942 ft
I'm specifically interested in knowing if the DJI OEM prop guards for the Mini work on the Mini 2.
2020-11-8
Cients
Flight distance : 5537369 ft
Portugal
Do you know if the propellers are compatible?
2020-11-8
GaryDoug
Flight distance : 1292802 ft
Seisiuneer Posted at 11-8 12:16
I doubt it. The arms on the Mini 2 are thicker (top-to-bottom and front-to-back). I just tried to fit some older 3rd party prop guards to my Mini 2 and they would not clamp on.
The props on my new Mini 2 are definately stiffer than the original ones on my Mini. I don't know if they would even fit, but I would not try to use them if they did.
2020-11-8
DJI Stephen
Hello there Juke. Thank you for reaching out and for the inquiry. These are the DJI Mavic Mini accessories that is compatible with the DJI Mini 2. The Mavic Mini DIY Creative Kit, Mavic Mini Snap Adapter, Mavic Mini Propeller Holder, and Mavic Mini Intelligent Flight Battery of the international version of Mavic Mini are compatible with the international version of DJI Mini 2. Although the international version of DJI Mini 2 can use Mavic Mini’s battery, the power will decrease and the total weight will exceed 250 g, requiring registration in some countries and regions. Please check local rules and regulations before use. Thank you.
2020-11-8
djiuser_k6kL2eEGRzOQ
Flight distance : 1254944 ft
Kosovo
Helllo i have a question does the mavic mini 2 arm shell without motor fits on mavic mini 1 ?
1-14 09:50
djiuser_pbG2yqrWUJ24
Which other drones have propellers that are compatible with Mavic Mini? Some have told me that Mini 2 propellers will fit the Mavic Mini but no one seems to know for certain.
My issue is that I can't find non-OEM propellers for my Mavic Mini...such as red ones!
1-27 12:12
