Mavic 2 Enterprise Series Release Notes
3849 7 2020-11-23
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2020.11.24
  • Mavic 2 Enterprise Aircraft Firmware: v01.01.0800
  • Mavic 2 Enterprise Dual Aircraft Firmware: v01.01.0800
  • Remote Controller Firmware: v01.01.0430
  • DJI Pilot App Android: v1.9.0
  • DJI Pilot App iOS: v1.1.4
What’s New?
  • Optimized anti-interference of image transmission in some scenarios.
  • Improved stability of RTH for Mavic 2 Enterprise Dual in certain scenarios.
Notes:
  • Once updated, Android system, DJI pilot app v1.9.0 is recommended.
  • If the update fails, restart the aircraft, remote controller, and DJI Pilot or DJI Assistant 2 for Mavic, and retry.
2020-11-23
ABeardedItalian
Flight distance : 1063107 ft
Thanks for sharing.
2020-11-27
Syntropix
Flight distance : 697552 ft
Bulgaria
After the update of M2ED fw 01.0800 and DJI Pilot 1.9.0, the selectable options for the thermal camera are not assigned and do not work from the 5 D buttons. Anyone have a similar problem?
2020-12-13
Syntropix
Bulgaria
Hello, do some have the same problem with the 5-D button when updating to fw.01.0800
2020-12-17
djiuser_ZfPancqz8iPM
India
Hi,
I am using Mavic 2 enterprise for thermal data capture in solar power panels, the image is blurred and not clear where as the visual camera's images are very clear. I am flying at 2m/s and 20m altitude, 5.5 GSD with 640 X 480 resolution.
Attaching sample data for reference.
2020-12-25
Syntropix
Bulgaria
djiuser_ZfPancqz8iPM Posted at 12-25 10:03
Hi,
It's normal. The IR camera is 160x120 px. For greater sharpness, use mixed mode MSX and adjust the docking between the IR and the visual camera for the altitude at which you are flying.
2020-12-27
Visatildeo Aeacuterea
Brazil
I m using a Mavic 2 Enterprise Dual and I cannot save a video with MSX while flying in Visible mode. I m always used this resource in previous version of firmware but in last version  the only way to record in MSX it´s flying in MSX but this way compromises the safety of the operation    previous version ( DJI Pilot 1.6.1 and Mavic 2 Enterprise Dual 01.01.0700) -> everything OK Last version (DJI Pilot 1.9.0 and Mavic 2 Enterprise Dual 01.01.0800) -> can't record in the background MSX while flying in visible  Flying in visible and record in MSX it´s a basic requirement for my business. For now I´ve chosen to stay operation in previous version but i would ike to keep me updated. please help me  to find a solution ...
2021-1-11
Syntropix
Bulgaria
Visatildeo Aeacuterea Posted at 1-11 18:44
I fly on M2ED with Pilot 1.9 and fw.1.800, in MSX mode it records both videos in MSX and Visual. Try to in HD resolution 1920x1080. I have no problems with the recording.Maybe you can do the update again, and fw 01.800 and Pilot 1.9. Good luck!
PS Also check the version of the RC controller fw01.0430 !!
2021-1-12
