JJB*
Flight distance : 12260774 ft
Chad1 Posted at 12-29 21:45
Yes it was a little cold, but nothing that I had not done before.
I had no issues with wind operating at about 200-300ft. The issues arose when the aircraft unexpectedly ascended without input from myself. I have no idea how it got to 1000+ feet, let alone 8000+ feet, but yes the wind and cold would likely have been some sort of factor at that height.
Hi,
Its a waranty case. IMU error; climbing with a vertical speed indcation going down.
Baro Height increases from 1639 to 5379 feet in 0.1 second....IMU error.
Look for DAT file on your mob device, its FLY015.DAT, imu errors in there for sure.
Due to IMU errors your MM in ATTI for some time, drifing away. Plus in Normal mode and RTH craft heading more or less towards home but did not come closer to home, more distance away...guess not able to win form the wind.
Last position in the log : 43.89310300, -78.93704200 at a height of 2447.5 meters, height is incorrect so mayby lost connection bc mini low to the ground.
Summary of errors too big for 1 screen....so if you like download Summary.xlsx from > https://mega.nz/file/JWJQkTrR#lw ... ezHnbA1PwY_NAJyDhUs
cheers
JJB |
