Sequential file naming
4594 10 2021-1-2
Droning-On
Flight distance : 293058 ft
New Zealand
Is there a setting that I'm missing to enable sequential file naming?
It gets a bit confusing if I'm copying files into a common folder.
2021-1-2
Labroides
Flight distance : 9991457 ft
DJI Go 4 gives the option of continuous file numbering (but only to 999).
But that's not possible in DJI Fly.
Try copying each flight's images to a new folder rather than dumping everything into the same folder.
2021-1-2
DJI Gamora
Hi, Droning-On. Thanks for reaching out! Currently, File Index Mode isn't available to the DJI Fly but we'll forward this feedback to our developers. After the evaluation of the engineers, significant suggestions or requests will be implemented via the firmware update, app update, etc. For any updates, please stay tuned to the latest news on our DJI official website at www.dji.com or by checking the Release Notes.
2021-1-2
KnNLmS
Flight distance : 119967 ft
Turkey
DJI is rediscovering America in all new product and software. Hard to undertand...
2021-1-2
Renato61
Flight distance : 168163 ft
KnNLmS Posted at 1-2 05:56
And when Dji makes a change to catch up, seems to have invented teleportation
2021-1-4
ZarcTheSpark
Flight distance : 460676 ft
I don't know if this works on the MIni 2, but on the Spark, if you left an old file on the SD card, but erased all the rest of them, the sequential numbering would pick up from that file name.
2021-1-5
Gif2Dtrade
Flight distance : 528478 ft
Romania
Maybe instead of sequential name, it can store date&time in filename in a YYMMDDHHMMSS format…
I managed to rename them manually, as I didn't shoot many videos/photos per session.
2021-1-5
djiuser_1g1NanF7ar4K
Flight distance : 91565 ft
DJI Gamora Posted at 2021-1-2 04:50
This is very important missing functionality. Please escalate to engineering... Thanks in advance.
2022-6-24
Labroides
djiuser_1g1NanF7ar4K Posted at 6-24 14:12
Although the feature is missing in the app, you can still have continuous file numbering if you format the SD card in your computer after copying the images to it.
Format in the drone and it will reset to 001 every time.
2022-6-24
Sean-bumble-bee
Flight distance : 15997 ft
Or simply DO NOT reformat when you empty the card.
2022-6-24
dcsergio
Flight distance : 378110 ft
I had the same issue with my Mini 2. I solved renaming the file DJI_0001.JPG to the number I want to start from.
2023-8-19
