Mavic Mini Motor speed warning and propeller warping issue
2518 18 2021-1-3
djiuser_g2VkrietJXul
Flight distance : 13294426 ft
I looking for people that have had this problem, and want answeres. I have them BTW
2021-1-3
TomMahoney
Flight distance : 74701 ft
Constantly. Always the left rear prop. When I reset it and hover at a low altitude everything is fine. As soon as I go for a flight the problem returns.
2021-1-3
I'm really trying to create a discussion and offer my advice that is sound... if you use a small strip of self sticking velcro at least on bottom/back legs where the issue is this will solve the problem forever for you storing in any case even fly more case or even flat bottom case. Just attach loosely. That will work now why it works is the million dollar question lol
https://youtu.be/Rc-7x-_B_pA
2021-1-3
2021-1-3
I can't seem to share my you tube video hmmm
2021-1-3
2021-1-3
DAFlys
Hi! You might be better off posting your question in the 'products' section of this forum.  That is way more active.
2021-1-4
I'm just gonna let the pics and video do all the explanation. If you keep in mind that the entire head of the drone cut out in the case from motor cut outs to nose tip is the same flat level in the case Notice where the ridge starts and stops as well. Just as it sits on this flat mirror is as it would sit in a flat bottom case if it needed to as in such case as I have.  As far as the props are concerned it might as well be a totally flat case just like my flat bottom MPP Fly more case I modified and use for the Mini. Theres nothing more that the flatness of the bottom of the case can do than this flat mirror, EVEN IF IT REACHED but it doesnt even.. Then as you can see the that grey tape on the mirror would be where that raised edge/red line starts and stops. Any other way of folding them than directly across as you see will bend them at all random places depending on they lay each time. Start out with the design of the case and drone body lines. The red mark represents the grey tape i
2021-1-4
djiuser_g2VkrietJXul Posted at 1-4 03:53
The red mark represents the grey tape i used. Blades running directly under motors precisely. The raise in the case is 1/2 inch. The motors and prps and velcro thickness only 1/4 inch. The props never touch bottom in the fly more case this way. What all this means is that ANY OTHER WAY is bad news
https://linksharing.samsungcloud.com/nafrqrJSpH6r
https://youtu.be/cuGPaCuksek
https://youtu.be/UGYaGyWJG_I
https://youtu.be/uiFHdxhmSFw
https://youtu.be/Vkya7c-PMxs
https://youtu.be/VlvU22-BpwQ
https://youtu.be/V8TXJyoI4WU
2021-1-4
   C A S E   C L O S E D!!!
2021-1-4
Please tell me you can click on those videos  and photos
2021-1-4
I'm not sure how I can send all the evidence
2021-1-4
2021-1-4
2021-1-4
2021-1-4
It will not let me share my you tube videoes or a link
2021-1-4
TomMahoney Posted at 1-3 16:29
Im not sure how to get you the info you need smh lol
2021-1-4
TomMahoney
It did let me watch some of the videos. I like it. I'm currently trying not to put it in a case at all.
2021-1-5
So i finally figured it all out just by going through the motions and the facts on this speaks very loud. I'm gonna mostly let the pics and videos do a good bit of the explanation itself.  If you keep in mind that the entire head of the drone cut out in the case from motor cut outs to nose tip is the same flat level in the case Notice where the ridge starts and stops as well. Just as it sits on this flat mirror is as it would sit in a flat bottom case if it needed to as in such case as I have.  As far as the props are concerned it might as well be a totally flat case just like my flat bottom MPP Fly more case I modified and use for the Mini. Theres nothing more that the flatness of the bottom of the case can do than this flat mirror does to bend anything if you store it the way i have for a year now. Self sticking velcro strip i got off my MPP CHARGING CABLE. JUST A SIMPLE CABLE WRAP.  If you pay attention to my pics and video you'll see that storring your mavic mini this way is really
2021-1-5
