djiuser_pc3kG1wYnJ7Y
I'm having the same issue too. It doesn't sound as bad, but behaves in a similar manner. It has been consistently going crazy when it reaches a tilt of 40 degree angle. When I push manually move the camera there is normal push back except at that particular tilt angle. It starts to weaken and attempt to tilt up and or down. I've tried holding/rotating the camera as it tilts from down to up to guide it both fast and slow, but as soon as it hits that +40 angle, things go crazy. Wanting to swing the full spectrum.
I took off the side cover to the tilt axis motor. Disconnected the wiring harnesses and readjusted their positions and blew around a bit incase any debris was present. It started working normal for a bit, but then again misbehaved at much lower angles.
I've also tried reseting everything. Lowering the stiffness seem to help a little bit, but it still seems sensitive at a particular tilt angle.
No solution yet. May have to send it in for repair. |
