Drone rotates instead of gimbal
584 7 2021-1-27
djiuser_YDso2sK4VXB6
Belgium
I have an issue while trying to use the gimbal of my Matrice 300 RTK. I need to make a producedure to take a set of picture at different angles. For that I use the gimbal.rotate() with a rotation in absolute but when I do that and the drone is in the air it is the drone which rotate and not the gimbal. Where is the problem? The gimbal is set in FPV mode
2021-1-27
hdrpano
Flight distance : 598458 ft
Switzerland
Set gimbal to free
2021-1-27
Belgium
Yes but then the 0° is set to the north and not the aircraft face
2021-1-27
kv886
djiuser_YDso2sK4VXB6 Posted at 1-27 05:29
Yes. I think you can get the aircraft heading at the same time.
2021-1-28
Belgium
Yes but it's not precise then...
2021-1-29
Belgium
up, anyone having idea?
2021-2-9
Mats Bohlinsson
Flight distance : 1838077 ft
Sweden
Since you don't give much info, I have to guess :-)
I've seen this behaivor on mavic 2 when in it's P-GPS-mode.
Enable virtualstick and you will get locked heading.
2021-2-13
Belgium
It seems to work but when the drone goes in WayPoint mission for example the problem get back :/
I had to modify the whole concept of the application to avoid this
But thanks
2021-2-14
