What is your light color on mini 2?
3905 18 2021-2-12
Creed Jett
Flight distance : 5909 ft
I was just wondering what you all had your color set to on the drone light? And more importantly what color do you think helps you see better for night flying?
2021-2-12
Akirasho
Flight distance : 1622238 ft
... it's a secret between me and the drone... I'll never peek and tell.
2021-2-12
yogi053
Flight distance : 26104915 ft
I chose the incognito black light for night time surveillance!
2021-2-12
ozoffi
Flight distance : 55128 ft
Austria
If the copter should be really clearly visible, the color of the LED doesn't really matter (white, yellow, light blue are more visible - but only a few meters) .... Then you will not get around an additional light ...
2021-2-12
FB: GeoDrone4K
Flight distance : 2676129 ft
Romania
Bright sand in a dark snow weather color )))))
I prefer light orange as it can be easily seen.
2021-2-12
Lucas775
Flight distance : 50642090 ft
Heartbeat purple on mine.
2021-2-12
Throbber
White on the bottom, Red on the top.
2021-2-12
djiuser_LSA2v8XVnCFw
Flight distance : 3600774 ft
I have mine set to orange
2021-2-12
DAFlys
Its adjustable?  How do you do that?
2021-2-13
yogi053
DAFlys Posted at 2-13 01:27
I think Throbber is referring to strobes he has fitted whereas the OP is talking about the drone light on the front which can be changed in the settings to various colours.
2021-2-13
DAFlys
yogi053 Posted at 2-13 06:54
where is the setting to change the front light color?
2021-2-14
yogi053
DAFlys Posted at 2-14 02:02
In the settings under control you can choose various colours and have it flashing or solid, ie non- flashing.
2021-2-14
DAFlys
yogi053 Posted at 2-14 04:57
Is there an option to just turn it off?
2021-2-14
yogi053
DAFlys Posted at 2-14 05:50
Yes, in control again use disable mode.
2021-2-14
DAFlys
yogi053 Posted at 2-14 07:30
Excellent,  thanks for the info.
2021-2-15
yogi053
DAFlys Posted at 2-15 00:57
No problem. Stay safe!
2021-2-15
DAFlys
yogi053 Posted at 2-15 02:38
thanks,  you too.
2021-2-15
Astro Bob
Flight distance : 9616 ft
I wondered about turning off the front light to save a bit of power which might extend flight time a bit more. Anyone done some tests to see if it makes enough difference to go for the gain. I would but right now it is Winter in the mid west and not likely to fly much for another month.
2021-2-15
KlooGee
Flight distance : 16783757 ft
Astro Bob Posted at 2-15 18:51
It’s a tiny little LED that you can barely see when it’s sitting on the table in front of you.  The amount of power it draws is likely so minimal there would be no affect on flight time.
2021-2-15
