Back leg loose from factory, what can I do
1720 12 2021-2-12
Neculai Deloiu
Flight distance : 987838 ft
Denmark
Hello guys,
I have bought an air 2 about 2.5 months ago, I have noticed after a few days that there is more space between one back leg and the body, than the other one, since that space got bigger, it has now about 2 or 3 mm space between the mounting of the leg and the body - I will attach here the photos
Note: I managed to write to Dji via Dji Fly app, contact support page, described my issue and added photos, it passeed about a month, no reply
What should I do?
Is there anyone having such an issue with their quad legs. To me, it seems that right back leg somehow it was not tighten enough, as I have this feeling that it gets bigger with every folding and unfolding
Please help a newbie
P.S. no crushes so far, so I cant see why this is happening to my newly drone
I look forward to any input from you guys
2021-2-12
Neculai Deloiu
Denmark
deleted
2021-2-12
Neculai Deloiu
Denmark
deleted
2021-2-12
FB: GeoDrone4K
Flight distance : 2676129 ft
Romania
Trimite-o in garantie de unde ai cumparat-o...simplu...
2021-2-12
Neculai Deloiu
Denmark
deleted
2021-2-12
JohnLietzke
Flight distance : 3125968 ft
You could try a warrantee claim.  Or you could go rogue and loosen the set screw and push the leg further down then tighten it.
2021-2-12
Fert
Flight distance : 222516 ft
JohnLietzke Posted at 2-12 10:45
I say go rogue.
2021-2-12
DAFlys
Go rogue.
2021-2-13
Neculai Deloiu
Denmark
deleted
2021-2-13
Fert
There's a screw on the top and one on the bottom, you need a #5 torx driver.  Just for the heck of it, I decided to take both screws out of mine and slide it out slightly like yours.
Not sure exactly why yours has moved like it has, but I would definitely try taking both screws out, push it in and reinstall the screws.
Good luck
2021-2-13
DAFlys
Neculai Deloiu Posted at 2-13 09:28
I thought the same, to save waiting time, headache, I might just do it myself nice and easy, but, i might loose the warranty this way, right?
Plus, I am not sure if is due to the crews from the leg/ outside, or I need to tear all the inside out, and fix the leg from where is connected inside?
Unless the screws have a glue in them they'll never know.
2021-2-14
Raf_IZ0QWM
Flight distance : 1640843 ft
If there is a "glue" it is threadlocker, and it can be removed by heating it calmly, without damaging the plastic.
2021-2-14
Neculai Deloiu
Denmark
Thank you to all of you that took the time to write an opinion. I will have someone that works with drone repairs look at it. For my next drone, I will surely take the Dji Care refresh
2021-2-20
