RESOLVED - Phantom Assistant will not connect
2785 3 2015-7-10
Cessna172
Hello,
Trying to get my Phanton 1.1.1 to communicate with Phantom Assistant
Here's what I've done...
1). Downloaded NAZAM Assistant 2.20  (From Phanton 1 download section)
2). Downloaded Windows DJI Driver (From Phanton 1 download section)
3). Installed Battery into Phantom (but not yet connected)  (fully charged)
4). Connected USB cable to gray USB connector from Phantom
5). Turned on transmitter
6). Connected Battery to Phantom Battery connector (Phantom powers up)
7). Installed Windows Driver onto PC (AMD, Windows 7)
8). Restarted PC
9). Installed NAZAM Assistant 2.20
10). Restarted PC
Tried uninstalling driver and assistant and reinstalling several times.
Cannot ever get a connection
Anything obvious I'm doing wrong?
2015-7-10
Texan4ut
Flight distance : 1161 ft
With the copter connected I had to go to this PC Win 8 and find the connection then I hit troubleshoot and it said searching fro driver. When it found it I clicked ok to download and it loaded up the driver and I connected. Not sure how it works in Win 7 but you probably  know how to.
2015-7-10
Cessna172
Ok, all good.
I have two computers.  My main computer and my wife's laptop.
Under no circumstances could I ever get connection on my main computer.   Now I can say it probably has issues withthe serial bus that affects it's ability to communicate over the COM port for the DJI Win driver.
I had tried my wife's laptop on day one with no luck there either.   Same problem connecting so I began to assume it was the Phantom's NAZA or VU module.
Today I went back to her laptop, removed boththe Wind driver and assistant, then re-installed the DJI Win driver doe Windows 7 AS ADMINSRTATOR.
During the procedure it asked me to power up the Quad and plug it into the computer....I did
That finished successfully
Next I installed the Assistant (never disconnecting the Phantom).   Again I ran the install AS ADMINSTRATOR.
After installing the Assistant I launched it AS ADMINSTRATOR and to my great joy, it connected immediately.
Now it seems to connect almost instantly every time so I am thrilled to know that I may not have to send the Phantom back after all.
I love happy endings.
2015-7-11
DJI-Dave
This is good to know. I will keep this info for future reference. Thanks.
2015-7-13
