noise in gimbal with freewell filter
978 4 2021-2-23
djiuser_bUpUyeQed5J2
Flight distance : 117628 ft
I have installed a freewell filter in my mini 2, I have observed before testing it that when I turn it on the gimbal emits a hum, as if the motor were making more effort. I would like to know if this is normal.
2021-2-23
Lucas775
Flight distance : 50642090 ft
Not normal I can say this since I have a freewell filter as well.
2021-2-23
DJI Stephen
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Since this is a 3rd party accessory for your DJI Mini 2 I hope that you will get the best recommendation from our DJI co pilots on with regards to the use of this ND Filter. Just a reminder if you will be putting this device or a 3rd party accessory like ND filters on your DJI Mini 2, it will add weight to the said DJI drones gimbal and it might affect the performance of the drone in flight and can also void the warranty of your DJI Mini 2. Thank you and fly safe always.
2021-2-23
DJI Stephen Posted at 2-23 19:51
Gracias por contestar.El problema es que no hay filtros  DJI para el mini 2,por eso me decante por los freewell que son bastante ligeros y otros usuarios los usan sin mayor problema.Por eso me extrala que mi aeronave presente problemas al montar este filtro que solo pesa 0.8 gramos.
2021-2-24
DJI Stephen
djiuser_bUpUyeQed5J2 Posted at 2-24 04:41
Hi there. Thank you for the reply and for these information you have given. Rest assured that I will forward these information to the designated DJI department for further attention. Thank you.
2021-2-25
