ozoffi
![](https://forum44.djicdn.com/data/attachment/common/aa/common_14_usergroup_icon.png) Second Officer
Flight distance : 55128 ft
Austria
I use the memory card which you are say myself in a GoPro with 4k60FPS - the SD card is fast enough for the DJI Mini2.But have you already formatted the SD card in the drone via the APP?
In which resolution and frame rate do you record?
Try this also with 50 / 60FPS or set the yaw rate under control with extended gimbal control e.g. in cinemode to 6 degrees / second, then even at only 25FPS when rotating around its own axis, no more stuttering should be seen.
Why there are dropouts, however, I find very strange - that shouldn't happen!
