ranrick
Flight distance : 8743645 ft
Philippines
Personally, I don't think they are that useful. Particularly because I keep my MM in the case out of dust and exposure when not in use anyway. And when I'm using it, the propellers spinning essentially give some sort of cover for the motor windings already. Plus the motor windings should already be coated with insulation material for them to work in the first place. Best that can do is provide some small protection if you encounter rain but then again I would be highly against flying in rainy conditions and be sure to check the weather forecast beforehand. |
