Mavic Air 2 48mp Photo Quality.
1006 6 2021-4-5
b9y
Flight distance : 704751 ft
Hey all.
On the DNG and JPG for this photo, the quality seems awful. The amount of noise for something which is meant to be 48mp doesn't seem right, despite the sensor size. I've highlighted the amount of noise, and this is in bright sunlight with ISO set to 100. Please tell me this isn't normal? I've seen photos which are monumentally awesome from the Mavic Air 2, but this doesn't seem to match.
Also, does a higher shutter speed mean more noise too? I've read similar things, just wanted DJI admin's thoughts.
Screenshot 2021-04-05 at 20.39.35.jpg Screenshot 2021-04-05 at 20.42.30 copy.jpg
Thanks.
2021-4-5
itsdavesdrone
Flight distance : 6763835 ft
Be wary of the 48MB mode. It isn't a 48MB camera. It is a 12MB camera which uses Quad Bayer tech to create a 48MB image. So in some scenarios you can actually introduce noise using it because of the way the tech works. So you might find some 48MB images are grainier than the 12MB versions but they will look like they hold more detail.
2021-4-5
b9y
itsdavesdrone Posted at 4-5 13:59
So is the "single" shot photo mode just the normal 12mb? And if so, what's the difference between that mode in 16:9  or 4:3? It's  a bit  confusing. Thanks.
2021-4-5
itsdavesdrone
b9y Posted at 4-5 14:35
Yes normal mode is 12MB. You have to decide you either take high-resolution shots with a lot of detail in 48MB which can cause noise and grain issues, or lower-resolution images with better dynamic range. It’s a tradeoff that you choose.
Use 4:3 format. 16:9 is a cropped version of the image. 4:3 gives you the maximum image size and you can crop if you need to.
2021-4-5
Labroides
Flight distance : 9991457 ft
Since you've only posted screenshots of parts of the images, it's not possible to comment on the quality of your images.
No ... and you're not going to get any kind of answer to that from moderators.
2021-4-5
b9y
itsdavesdrone Posted at 4-5 15:32
Ok thank you
2021-4-5
b9y
Labroides Posted at 4-5 16:26
I can only upload 1mb max images here. I'll upload on a link site tomorrow. I mean the noise is pretty apparent.
Regarding the admins, no worries. Thanks.
2021-4-5
