Audio
677 5 2021-4-6
Avronaut
Flight distance : 53996 ft
Is there audio only in the goggle and not on the drone recordings?
2021-4-6
eisenfliege
It is only in the recording if you switch the setting for sound recording on. It is off on default.
2021-4-6
Avronaut
eisenfliege Posted at 4-6 03:54
Ok. Thanks!
2021-4-6
DJI Stephen
Hello there Avronaut. Good day and thank you for the inquiry. Kindly please refer to eisenfliege reply on post #2. For additional reference I will post a link where in you can check the DJI FPV's user manual. Thank you and keep flying.
https://dl.djicdn.com/downloads/ ... _User_Manual_EN.pdf
2021-4-6
nOxxxx
Flight distance : 80646017 ft
Poland
I have audio recording turned on and it is recorded to the sd card in the drone. Unfortunately, there is no sound in the headphones during the flight and no sound is recorded on the sd card in the goggles. If I insert the sd card from the drone into the goggles, the sound is played on the headphones. Where is the problem?
2023-9-6
nOxxxx
Poland
The sound in the headphones returned, but only after downgrading to version 1.4.0000. DJI, why are you doing this to us? In all newer versions of the goggles firmware, the raicer microphone sound is turned off in real time. It will only be recorded to the SD card in the drone.
2023-9-6
