JJB*
Flight distance : 12260774 ft
Hi,
Had a look at your flight.
I am no specialist in no fly zones or airport zones ect, but the data in the log shows
a) 2 times : "Current RTH route will pass a no-fly zone. Pay attention to the aircraft's position to avoid RTH failure"
b) Aircraft will automatically descend in 14 ; wich means normally craft try to lower to avoid height limitations of the zone, but your drone was flying at 17.5 meters....but in the airport zone.
c) During RTH it entered or was alreadythe airport zone, so it did a " AirportAvoidLanding", software does not allow a drone to fly through an airport zone in RTH mode.
If all is correct you have to check the zone and the positions of your drone, but this is how DJI software works.
I checked the no fly map, the height limit Nosara airport is 60 meters at drone position. So mayby your drone was still alive when you did not engaged the RTH.
But ofcourse if DJI software is really intelligent than it could allow your drone to RTH at 30 meters where the limit is 60 meter. But nah, because the reference height to the RTH height setting is reference to take-off position, so your 30 RTH height could be higher than the actual 60 meters AGL/ASL height.Plus flying already in the airport zone it will just land.
cheers
JJB
