Light damage to battery port, is it dangerous?
665 2 2021-4-24
JoePsysky
Flight distance : 22861 ft
Bulgaria
Hi guys, the clumsy idiot I am, I dropped my battery from a meter and of course it found out the perfect angle to fall on and break two plastic separators in the port. Here is how it looks like:
Of course I immediatelly tested if it works and it does, no problem. Drone flies normally and also battery charges normally. My questions are:
1. Do you guys think this could be potentially problematic for usage?
2. Do you think this damage is possible to repair (By specialist in dron repair shop)
Thanks!
2021-4-24
LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi,
You can simply try to glue the piece back together with epoxy glue. Or make a new one with a 3D printer, by cutting a piece of plastic... This way you prevent a potential contact between the two points. If the piece of plastic comes off when you insert it, you won't be able to insert your battery properly.
But more generally, a shocked lipo battery can be potentially dangerous. When recharging, you have to take precautions to avoid a fire. As for flying the Mavic with it, I can't give you a formal opinion. Personally, if the shock was not too big, I would do a charge cycle while watching that everything is going well. If so, then I will do a small test flight in a secure area.
Up to you ! You can also send it to DJI for repair, but since it is out of warranty, it will be probably cheaper and safer to buy a new one.
Jordane
2021-4-28
JoePsysky
Bulgaria
Hi Jordane, thank you for your reply. The shock was minimal, just really precisely unfortunate. I tried charging and flying with it. I even went on a normal exploitation with it and there was no problem, so I guess i will be really cautions with those exposed pins and always watch out how I put the battery in the slot.
2021-4-29
