camera mal orientée
377 4 2021-4-28
Vairez Franccedilois
Flight distance : 158727 ft
Bonjour,
je rencontre le problème suivant, malgré mes essais de réglage, la camera de mon P4pro+ n'est pas droite , trés gènant pour réaliser un panoramique dont la première photo doit imperativement ètre orientée au nord exact. toute solution sera la bienvenue
cordialement
François Vairez
Drône servces 57
2021-4-28
DJI Stephen
Hello there François Vairez. I am sorry for the trouble this has caused and thank you for reaching out. May we know before this issue occurred was there a hard landing or a crash that happened before to the said DJI Drone? In addition kindly please try to calibrate the gimbal of your DJI Phantom 4 Pro+ as well to see if the issue will still persist. Thank you.
2021-4-28
Hello Stephen,
No hard landing and i tried to calibrate gimball several times without succes. I think i have to send my Drône at DJI réparation service.
Anyway thanks for your answer
2021-4-28
LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi Francois,
I had the same problem on a different version of the P4. Downgrade / Upgrade Firmware -> IMU Calibration -> Compass Calibration -> Gimbal Calibration. Then you can adjust the position of the camera in the menu. It worked for me.
2021-4-28
LV_Forestry Posted at 4-28 23:04
Hi Francois,
thanks LV i'll try this solution , hope it will work
2021-4-28
