So.... What actually IS the point of the nose LED on the Mini 2
1195 9 2021-5-5
PhasedSpaces
Flight distance : 185463 ft
A Gimmick or does it actually provide a real use, that user feedback for the original Mini, was a feature everyone was screaming out to have..?
OR, just to stir the pot, 'could' DJI have instead put forward facing collision avoidance sensors there, that everyone WAS screaming out to have? -  ESP given that with the Lipo battery, the Mini 2 is actually around 241-2g in takeoff weight now ... Plenty of room weight/mass-wise to add componants weighting a couple of grammes?
This begs the question, 'could' DJI have put forward facing sensors in instead of a 'flashy'l LED thing, & still kept the drone below 249g?
Just asking.......
2021-5-5
yogi053
Flight distance : 26104915 ft
Yep! I wondered why they would go to all that trouble to have a multi-coloured, different action LED on the front of the Mini 2. After all, it doesn't really serve any real purpose, does it?
2021-5-5
HomePoint
Flight distance : 776007 ft
My computer has LED RGB lights that do not serve a purpose, I like them though.
2021-5-5
videoeditman
Flight distance : 6713271 ft
The LED is also a button, I don't currently remember what it does. Also in the dark you could tell which way it is facing. what else???
2021-5-5
dingo_do
Flight distance : 78780 ft
videoeditman Posted at 5-5 10:10
The one on the back is a button, the one on the front is not.
2021-5-5
videoeditman
dingo_do Posted at 5-5 11:29
You are correct, that's what happens when you don't use it a night!
2021-5-5
lacibaci
Flight distance : 235682 ft
Adding collision avoidance would add a lot of CPU load and battery drain. Also, why would anyone buy Magic Air if Mini could do the same?
2021-5-5
GaryDoug
Flight distance : 1264639 ft
OP: It needs two sensors for OA in one direction (1 transmitter and 1 receiver) and they would be much larger than that one LED.
2021-5-5
DJI Stephen
Hello there PhasedSpaces. Good day and thank you for these information you have posted. The DJI Mini's front LED shows the orientation of the said DJI drone and pulses white when the aircraft is powered on. Thank you.
2021-5-5
DAFlys
The rumour was that slot was going to be forward sensor but it wasn't ready on time.
2021-5-5
