Unstable drone video inside
1023 4 2021-5-6
kopterue
Serbia
So i've purchased my drone like 2 months ago and i thought everything was ok untill during my flights i noticed sometimes it doesnt follow direct line but rather turns a bit to the left/right when trying to move straight... I thought its pilot error as i was new to flying but then i tried DJI mavic air 2 and i noticed huge difference in stability and flight. My friend told me to put drone up and to watch it if it stays steady in the spot and i noticed that it was very very unstable. Sometimes when i let it sit in one spot for few moment (without touching controller) it starts to narrow left and right as i was in ATTI mode. I recorded a video to show you how it looks like without touching controller.
Keep in mind i callibrated all 3 attributes (compas, IMU, controller) and i had 10 signal on GPS. There was no wind sign at the moment of recording.
Sometimes its even worse then on this video and it sometimes goes even more to left/right.. It acts very unstable! Sometimes following straight line works but sometimes it loses focus and changes angle a bit to the right/left...
What can i possibly do?
2021-5-6
DJI Stephen
Hello there kopterue. I am sorry for the trouble this has caused and thank you for reaching out. May we know before this issue happened if your DJI Phantom 4 Pro had a hard landing or a crash before? In addition, can you please try to fly the said DJI drone in a different location with less interference to see if there would be some changes? Also, please try to check whether you are currently using the most recent firmware as well. If not, kindly please update the said DJI drone's firmware to it's latest version for us to isolate the said issue. Thank you.
2021-5-6
Geebax
It may be affected by that big wrought iron gate it is hovering over, or perhaps you took off from the concrete in the back ground, which may have re-inforcement steel in it.
2021-5-7
Labroides
Flight distance : 9991457 ft
Understand the limits of the drone's ability.
Some minor position holding variation is unavoidable.
Here's an important detail from the specs:
Hover Accuracy Range
Vertical:
±0.1 m (with Vision Positioning)
±0.5 m (with GPS Positioning)
Horizontal:
±0.3 m (with Vision Positioning)
±1.5 m (with GPS Positioning)
2021-5-7
Goldenseal
Flight distance : 487034 ft
Do not update till the problem has been investigated further. Try it with the sensors turned off. That is how mine flies over beach sand or water. I have to turn the sensors off.
2021-5-7
