can I set camera resolution (still frames) on Mavic Pro
826 7 2021-5-15
benkelman
I have a Mavic Pro.  I see how to change the video resolution, but the only settings for still frames are 16:9 and 4:3.  The images are 4000 x 3000 pixels but can I change that to a different resolution?
2021-5-15
DAFlys
No you are fixed at this resolution but you can always downscale them later.  Also the 16:9 is just a crop of the 4:3 image.
2021-5-16
Labroides
Flight distance : 9991457 ft
Why would you want to shoot at any smaller than 4000 x 3000 anyway?
2021-5-16
benkelman
Thanks - yes, I can downscale later but that takes an extra step and the 4000 x 3000 resolution frankly is a waste of disk space - it's beyond the optical quality of the lens.  I'm shooting hundreds of nadir photos for processing in Drone2Map so was hoping I could simply record the appropriate resolution at the source.   oh well, thanks for confirming so I can stop searching.
2021-5-16
benkelman
Labroides Posted at 5-16 07:04
Labroides, the 4000 x 3000 is oversampling the resolving power of this lens.
2021-5-16
Labroides
benkelman@yahoo Posted at 5-16 07:10
Congratulations, you've come up with something I've never heard before.
Whether that's true or not, I'm puzzled that you are such a perfectionist pixel peeper and you are using a 12MP Mavic Pro and what you are getting so fussy about mapping jobs.
That's amazing
2021-5-16
benkelman
I guess I am often guilty of being a perfectionist but to me it just makes sense to optimize your system where possible, and if I'm storing thousands of photos that are (I'm estimating) about 2x oversampled, that's 4x the data volume.  4x the data to store on the SD card, transfer to disk, and then process (either to generate data products or downsample 2x first).
I can't tell if you're interested in this but I'll shoot some resolution targets and post an example of what I mean - but that'll take a week or two - need to build the targets first.
I assume your comment about the 12MP Mavic Pro means "if resolution, accuracy, etc. are so important, get a better drone" and you're right that this is not a high end/professional drone - but it's mostly hobby and research for me, so I started with what I could afford.
Thx
2021-5-16
GaryDoug
Flight distance : 1264639 ft
benkelman@yahoo Posted at 5-16 20:45
I guess I am often guilty of being a perfectionist  but to me it just makes sense to optimize your system where possible, and if I'm storing thousands of photos that are (I'm estimating) about 2x oversampled, that's 4x the data volume.  4x the data to store on the SD card, transfer to disk, and then process (either to generate data products or downsample 2x first).  I'm can't tell if you're interested in this but I'll shoot some resolution targets and post an example of what I mean - but that'll take a week or two - need to build the targets first.
Very well said.
2021-5-16
