Air 2 jello
902 6 2021-6-11
djiuser_3uiA3mLhquon
Flight distance : 674665 ft
Poland
Hello,
I would like to ask if it's normal for air 2 to have this kind of jello vibration over footage as here below:
It can be visible even more when I go to manual mode and set shutter to low value like 1/2000s
60% - 80% of my footage is unusable,
Note:
- No error messages
- Drone never crashed / no damage
- No filters over lens
- Original propellers
- Latest firmware
Can this be fixed under warranty?
2021-6-11
DJI Gamora
Hi, djiuser_3uiA3mLhquon. Thanks for reaching out! Please let us know if you're only experiencing this when the video is zoomed in digitally. If you haven't tried, we suggest doing a gimbal calibration and see if that also helps.
2021-6-11
Poland
DJI Gamora Posted at 6-11 04:55
Hi, gimbal calibration does not help at all, other calibrations too...
In this case I zoomed in to show it better. It also happens in every other mode. On live view and footage. It's more noticeable when the drone is hovering.
Here you can see it on normal footage.
https://youtu.be/DnaLJcMqKlg
2021-6-11
MySky
Flight distance : 364902 ft
How old are your props. Maybe try a new set of props.
2021-6-11
Poland
MySky Posted at 6-11 08:41
I bought props set just a week ago, it's still the same jello.
2021-6-11
Rustic17
Flight distance : 2733760 ft
No, it's not normal.  I've never seen it with my drone.
2021-6-11
DJI Gamora
djiuser_3uiA3mLhquon Posted at 6-11 05:13
Please update or refresh the aircraft's firmware via the DJI Assistant 2 then perform another test to confirm if the problem can be resolved.
2021-6-12
