Ronin M not working in Briefcase mode and one other problem
3049 7 2015-7-21
ezam.tahir
Brunei
Hi there,
I just got my Ronin M and it is a really great device, thanks DJI for creating such a project
However it does not work in certain ways, those are:
1. It enters briefcase mode weirdly. It doesnot work in Briefcase mode particularly the tilt of the camera, it will go pointing to the sky and stays like that
2. Panning on the not so working briefcase mode is not really working well. Whenever i pan, it will switch from briefcase to normal mode.
Other issues
1. Camera is all tighten up but it will go out of balance on a very small amount
2. Any tips on how to minimize footsteps while using ronin m
Thanks
2015-7-21
noipego
Greece
Have you enabled briefcase mode from the app?
2015-7-21
ezam.tahir
noipego Posted at 2015-7-22 02:28
yes i already did
2015-7-21
DJI-Cathy
Turn the handlebar 90 degrees from the gimbal, then swing the handlebar downward until the mode automatically changes. be slowly and pay attention the method, Briefcase mode and SmoothTrack must be activated in the Assistant app.
2015-7-21
ezam.tahir
Brunei
DJI-Cathy Posted at 2015-7-22 15:07
Turn the handlebar 90 degrees from the gimbal, then swing the handlebar downward until the mode auto ...
Yes, i do it slowly and it either doesnot work or drifts
2015-7-22
DJI-Cathy
ezam.tahir@gmai Posted at 2015-7-22 18:20
Can you please send your email to support@dji.com, we will help you, thanks a lot!
2015-7-23
The Media Clini
New Zealand
I have the exact same problem. I've just contacted DJI but haven't heard anything back yet. Were you able to solve the problem? If so, how?
Thanks!
2015-8-12
Karl Allemyr
Sweden
Hi,
Did you solve the issue? How was the balance of the gimbal in briefcase mode?
2018-8-24
