GPS Strength a function of Battery?
1184 7 2014-11-25
thadjscott
im new to the Phantom 2 Vision +. I began my test flights and followed the start up process to the tee. I started flight with 6 GPS signals and during flight it dropped to 5. I immediately brought it home as it began to drift. I started over by turning everything off. Same thing.
I put in my second battery and got 12 GPS's. I found it odd and put back the other battery and same thing 6 GPS's. It appears the battery is doing something to the GPS strength.
Any ideas?
Thanks for any advise.
2014-11-25
Dragonrider
Was there a difference in the strength of each battery??
2014-11-25
thadjscott
Both were fully charged.
2014-11-25
rod
New Zealand
Now that is very interesting!!! any chance DJI may reply to this?
2014-11-25
DJI-Autumn
China
Take a screenshot of the Upgrate page pls
2014-11-25
thadjscott
Quick Update.  I just did another test with both batteries.  Both are showing 6 Sat's at the location I'm currently at.  I will go back to my test zone and redo the test from yesterday.  I will also connect to the assistant and get the battery information after the next test.
2014-11-26
T J Gilbert
Flight distance : 74659 ft
Sorry, but one observation does not a test make...
You need to try the different lipos at different locations and times of day to get a set of data to base your theory on.
You are already seeing a difference in your first and second observations...
These craft exhibit strange behavior quite frequently, so it's best not to jump to conclusions.
2014-11-26
DJI-Autumn;-)
China
thadjscott@yaho Posted at 2014-11-27 00:24
Quick Update.  I just did another test with both batteries.  Both are showing 6 Sat's at the locatio ...
Could you pls take a video of this issue to make it more clearly?
2014-11-26
