Tethered Control Handle - tough to mount to anything
889 3 2021-6-20
SilentD1
Denmark
I just bought the tethered control handle only to find that its litteraly impossible to mount onto any accessories that dji has except for the Twist grip dual handle. The reason being that the bottom attachment screw has 2 pins comming out with it, which cannot be removed nor retracted. So if you already have the briefcase handle from your bundle and thought you could attach the tethered handle on to it.. Well you can forget about that. It will not fit.
And the top attachment while supposibly being a nato rail, wont fit on the switch grip dual handle from the Ronin S which supposibly also is a nato rail. Thats very curious to me how you intentionally made them not fit eachother by 1mm. I guess dji is not making enough money so they need to milk their customers for more accessories which are almost identical yet different. thanks but no thanks.
2021-6-20
Indio
Flight distance : 303373 ft
Austria
yes, DJI does not command or solve this problem :- (
2022-1-7
FX6_CrewMember
This or basically any other.
2022-2-1
7423
Flight distance : 12448 ft
Has anyone found an adapter for this? This is the only thing I could find so far:
DigitalFoto Solution Limited Adapter of DJI Ronin Tethered Control Handle on THANOS-PRO II/X
2023-9-18
