Switching between HDR video and photo mode
3223 1 2021-6-23
Viva Terlingua
Flight distance : 163862 ft
If you are filming in HDR Video mode and press the button to switch to photo mode and then press it again to switch back, it takes you into regular video mode.  Is there a setting where it can remember that you were in HDR video mode and take you back to it?
2021-6-23
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. If you are filming in HDR mode then go back to the photo mode, it is normal that the unit will return to the normal video mode and you need to select again the HDR option as this will record a new recording since you already cancel the first recording that you did consider that you switch to photo mode. Thank you for your continued support!
2021-6-24
