Multiple firmware updates to the same version? (v01.03.0000)
589 6 2021-6-25
sensiblesnake
Bulgaria
I got three prompts to update the firmware and did it three times but always ended up with v01.03.0000.  Each time afterwards I checked for new firmware and it said up to date, then some minutes later it prompted me to update the firmware which I did and again I ended up with v01.03.0000.  Has anyone else seen this?  What should I do if this keeps happening?
2021-6-25
IrishD
Flight distance : 140951 ft
where u swapping between batteries ?   it's firmware was updated too
2021-6-25
sensiblesnake
Bulgaria
IrishD Posted at 6-25 12:58
Oh right, maybe it is this. I have three batteries and maybe I just did them all.
Thanks.
2021-6-25
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Can you please confirm if the firmware update prompts appears when you switch batteries?  Also, as per IrishD on post #2, the battery needs an update as well that's the reason why you receive 3 firmware notices, if you switch on 3 batteries, then this might be the reason why. Please keep us posted. Thank you for your support!
2021-6-25
sensiblesnake
Bulgaria
I think it was probably the batteries and since I have three batteries abs I got this three times it should be done now. Thanks
2021-6-25
DJI Paladin
sensiblesnake Posted at 6-25 23:27
Hi, sorry for the late response. Can you please confirm if you still experience the same issue with your unit? Please keep us posted by hitting the "Reply" button. Thank you!
2021-8-15
Bashy
Flight distance : 2354357 ft
I didnt see that for my 4 batteries :/ just one firmware update....
2021-8-15
